senior member
Which is going to give me more power? a good set of headers or an aluminum intake and 4 barrel? im thinking the 4 barrel but any suggestions are helpful
i need all I can get out of a 307!
69 GMC bagged |
My other Love
an aluminum intake and 4 barrel will make more of a significant differnce
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Go with the intake and carb. Headers are more for higher engine speeds. A good dual plane manifold with the right carb will give you more low end power from off idle to, lets say 5000 rpm. But it all depends on what manifold you choose. I say let your right foot and your pocket book be the judge.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
Hi...If you think of your engine as an air pump(over simplification)..the more air in and OUT the more power. You will notice an improvement with a 4 barrel and intake, but you will see a much bigger improvement with headers too..now if you add a cam..which helps the engine take advantage of the other improvements..you will see the most gain. lets say 10HP for carb and intake..10HP for headers..and 15 HP for a cam...but if you install all 3..you could easily see 50HP gain..all of the parts must work together
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
its all about the +6 inches
And the cool thing bout heades and intakes, they will bolt onto your next (hopefully bigger) small block too.
Formerly yellow72custom
If you already have a 4bbl, get the headers. If you have a 2bbl, the 4bbl will make a HUGE difference. I installed headers on my 350, but i really couldn't make a judgement on the full throttle performance before and after because the engine wasn't broke in yet (i babied it until it got to 500 miles). The headers made it sound 10x as good though.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
If you don't have a dual exhaust, do that first and then do the intake and carb. This was what I did with my 307 and it made a huge difference. With the single exhaust and 2bl leaking carb and iron intake, it was pretty weak.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
senior member
ya were gonna put a performance aluminum intake and a 4bbl mayeb a mild cam not sure yet and yes i do have dual exhaust
69 GMC bagged |
