Sway Bar Install
I've read the write ups for sway bar install but just have one question. After knocking out the rivet, see photo and mocking up the bracket, I do not see another hole on the frame for the second hole. Do I need to drill this out? Is this the right location? Last question, which bushings work best, urethane or other?
Rollin' Old Skool
Re: Sway Bar Install
Follow what "Woog" says. And if you look here, you'll notice that I address this same issue (scroll down to post 69):
http://67-72chevytrucks.com/vboard/s...=514612&page=3 & there's a response in post #72
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
Thanks for the help. I will get started. Good thing I didn't remove the rivet. I'll let you know how it works out.
Hey also don't forget to mock it up with the bar loosely installed on the a arms so your geometry is correct. I had all of mine put together so I could use a floor jack and push the bar up to mark my drill holes on the frame.
Posted via Mobile Device |
Get out there ya lazy bastard!
Wow. Sorry. I somehow replied to another thread, but it showed up here!
Thanks, I went through TX firefighters write up where he shows removal of the rivet, just not sure about the second hole. I'll mock up with the a-arm brackets in place and see where I need to mount the frame mounts.
