Old 07-21-2015, 06:07 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
i need some ideas on how to do this
ok so i want to make a tail gate system without chains and hidden inside the bed for my 65 c10 longbed fleet .. now here is where it gets tricky i want it to be as cheap as i can but work well and not require any welding as i do not have a welder and also have never welded b4 in my life either lol ok the the price of this ide like to be able to keep at say $100 or less . so please would you guys give me some ideas and some directions on how to make this happen ? thanks Michael ... Happy Truckin
WOLFMANmike is offline   Reply With Quote
Old 07-21-2015, 06:34 PM   #2
LVPhotos
LVPhotos's Avatar
Re: i need some ideas on how to do this
http://www.mar-k.com/Catalog/m/mItem...ID=3213&CID=82
I used these.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-21-2015, 07:14 PM   #3
Evoracer
The ol' seat belt tailgate latch trick would be super cheap, if not free.
Evoracer is offline   Reply With Quote
Old 07-21-2015, 10:29 PM   #4
slepysal
slepysal's Avatar
I used gate latches that I had, and some Ford tailgate cables and the pivot bolt that I got from pick and pull. It is a weld free install I can take more pics
http://67-72chevytrucks.com/vboard/s...highlight=gate
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-21-2015, 10:56 PM   #5
spookylynx
spookylynx's Avatar
Hardware store slide bolt, like for a door or cabinet. Mounted on the inside of the gate.
spookylynx is offline   Reply With Quote
Old 07-22-2015, 12:17 AM   #6
WOLFMANmike
hey guys thanks alot for this info and ideas .. on all of these ideas how are you mounting the cables ? what piviot point bolts and also what ford cables are you using as in what year ford ? thanks again happy truckin
Old 07-21-2015, 11:59 PM   #7
Pappyx3!
Pappyx3!'s Avatar
Almost certain there is a section on the FAQ's about this. Check it out and let us know what direction you take. With pics��
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 07-23-2015, 12:05 PM   #8
slepysal
slepysal's Avatar
I went to pick and pull and took them off of a 90 something F150. The cables attach to pivot bolts on the F150 truck bed and are held on with a spring clip .I removed the cables and bolts . I will take some pics for you
Old 07-23-2015, 02:53 PM   #9
64shortbed
64shortbed's Avatar
Here is what i did to mine. but if you want hidden chains you would have to do something a little different for them but can tell you the handle and latch work great!
http://67-72chevytrucks.com/vboard/s...d.php?t=659201
64shortbed is offline   Reply With Quote
Old 07-23-2015, 02:55 PM   #10
64shortbed
64shortbed's Avatar
I did put my latch on the inside. Video link is on second page.
Old 07-23-2015, 04:33 PM   #11
WOLFMANmike
wow thats pretty trick bud ... i dont mind the cables being inside the bed ... i just thing the trucks look so much cleaner without the chains and latches on the out side .... i like yours too . but i think im more able to do the slide latches way .. but ty for your help
Old 07-23-2015, 06:58 PM   #12
64shortbed
64shortbed's Avatar
Yep mine had the slide latches for years before i figured out i wanted to do the latch like i did. I'm not a fan of the chains either. My cables are also off a 90-2000's ford.
Old 07-23-2015, 07:26 PM   #13
WOLFMANmike
ok cool ty so much Happy Truckin
Old 07-23-2015, 04:28 PM   #14
WOLFMANmike
ok cool thanks that would be great
