04-27-2009, 10:14 PM | #1 |
Brake pedal question?
I am changing from a stick to an auto in the '69 Suburban..
How do you get the brake pedal assembly out? I took out the column, the two bolts on each side of the column, I unbolted the brake booster from the studs, I do not see any other fasteners...Is it just a really tight fit, or am I missing something? Tommorow I will get a little more forceful with it. Thanks for any advice? |
04-27-2009, 10:28 PM | #2 |
Re: Brake pedal question?
Found this pic (From Longhornman's post) that shows a bolt way up top, and out of view...that might be my problem?
04-27-2009, 10:50 PM | #3 |
Yes, that bolt needs to come out but there's no reason to take out the whole mount unless you just really want to clean/paint it. You can just unbolt the lever arm from the clutch linkage and remove the clutch pedal.
04-27-2009, 10:53 PM | #4 |
The whole Suburban is coming apart...Damn Codes inspector does not share my love of unloved vehicles....
