Old 06-19-2007, 12:01 PM   #1
Imacarguytoo
Timing Issues HELP Please
OK heres a run down of whats going on. Its an early 70,s 350 witha stock timing cover from that year. I have set the distributor in at tdc with rotor button at #1 wire on the cap. The motor is at 0 degrees. I set the timing at 8 degrees. I have takin it for a drive and it still pings. Its got great power. But it also starts hard.
Anyone got any ideas of whats going on. This motor has less than 3000 miles. It had the points dist in it and ran great with no pinging. I changed it over to Hei and swapped out 3 hei's. But still the pinging and hard starting. Its my daily driver...todays my day off to fix it. Im really tired of messing with it. But its GOT TO RUN. The internals are stock.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 06-19-2007, 03:10 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Timing Issues HELP Please
moved to engine
rage'nrat638 is offline   Reply With Quote
Old 06-19-2007, 05:07 PM   #3
Imacarguytoo
Ok well...i burnt the starter up. I will get another 1 tonite for it. A friend of mine at a machine shop said to just time it by a vacuum gauge. He said hes seen too many times the mark on the balancer move. So i hope she will go with that.
Old 06-19-2007, 05:33 PM   #4
Billla
Billla's Avatar
Any time something changes, it's worth spending some time thinking about. Does the HEI have a solid 12V running to it? Are you 100% sure you have TDC located and #1 on the HEI located correctly?
Timing by vacuum doesn't work, and timing marks don't move very often...and if they do, it's time to replace the balancer as the outer hub has slipped. It's easy with a piston stop to find and mark TDC - happy to take you through it, I'm actually planning on doing a FAQ tonight with pictures.
Billla is offline   Reply With Quote
Old 06-19-2007, 05:56 PM   #5
Imacarguytoo
Is there anyway i can call you on my dime? PM me your number. I really gotta get her going tonite. I think it would be easier on the phone.
Old 06-19-2007, 11:05 PM   #6
Imacarguytoo
I have 12.24 volts at the battery. The same at the bat side for the hei. I put the starter on. It still wont start. I dont know what to do now with it.
Old 06-20-2007, 12:44 AM   #7
Imacarguytoo
Ive been thinking.....Ok what i mean by wont start is it will not turn over fast at all. Now i do have a fresh battery in it. Heres what im thinking. The purple wire going to the starter. What does it do. Does it just turn the engine over from the key?? If the wire is weak or hard as a brick (down by the starter) Will it maybe make the engine turn over slow?
Maybe my electrical system in the truck isnt up to par to run a hei? Maybe the motor is timed right and with low power from a bad wire will not allow the correct amount of juice to the dizzy. Maybe thats why it pings?? Is so how do i fix the problem?
Old 06-20-2007, 01:55 AM   #8
bills67
bills67's Avatar
Maybe the starter isn't getting the full 12 volts it needs to crank over. The resistor block I removed, as I understand it, took power away from the distributor, down to 9 volts, to allow the starter the full 12 volts it needs when cranking, once starter was disengaged the full 12 volts was returned to the distributor. It's been a few years since i did this. Thinking back there may have been some wiring going to the starter that also needed reworked. If you've got a maintenance manual (Haynes), find a wiring diagram for a newer truck, mid 70's, with HEI ignition and compare it to the points style. That's basically what i did, Wired the truck for the HEI. I also changed the spark plugs to match the ignition.
bills67 is offline   Reply With Quote
Old 06-20-2007, 07:20 AM   #9
Imacarguytoo
THe plugs are regapped to 45. Does anyone have a wiring diagram to compare for me. I dont have a chilton or haynes. The only wire going to the starter now is the purple and the big 1 from the battery....looks like i have 2 promlems now. Not turning over fast enuf and pinging. ARRGHH its my daily driver and im going to end up missing work over this truck.
Old 06-19-2007, 06:17 PM   #10
bills67
bills67's Avatar
The #1 plug location on the HEI is in a different spot than the points distributor, ensure this is correct first.
When i switched over to the HEI I had to remove a resistor block that dropped the voltage to the points distributor, during engine start, to 9 volts. When engine started 12 volts were returned to the distributor. This could be causing the hard starts. The HEI req's the full 12 volts at all times.
Old 06-19-2007, 06:20 PM   #11
Imacarguytoo
I ran a 10 guage wire from the fuse box to the hei. So the resister wire is not used now.
Old 06-20-2007, 06:31 PM   #12
Billla
Billla's Avatar
Cool beans.
You can get a stop from Summit and others - your local NAPA/Schucks probably has one...
http://store.summitracing.com/partde...5&autoview=sku
Old 06-20-2007, 07:38 PM   #13
jamis
F.A.S.T. president
jamis's Avatar
Sounds like your on the right track. you cant go wrong with what Billla was telling you.
For the next time you think your timing is so far advanced its not letting you turn your engine over, remove the hot wire to the dizzy and then try to turn it over without ignition spark. If it still doesn’t turn over or has a hard time turning over your problem is not an over advanced situation. Look to your cranking circuit.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
