02-22-2003, 07:03 PM | #1 |
gauge cluster question
I am thinking about buying a gauge cluster and maybe installing a camaro tach in it. Does anyone know what years of camaro tachs will work. I found a 1980 that looks like it will.
Also do tach dashes have extra light sockets for the tach? Has anyone put in a camaro tach and had good results? thanks. |
02-22-2003, 08:07 PM | #2 |
70-74 look the best IMHO because of the needle design. The camaro tachs from 70-81 will work fine though. As for as the lighting, there are 2 bulbs on either side of the tach after you install it and they seem to light up the speed/tach/fuel just fine.
I noticed my oil pressure guage was a bit dimmer but I think its because of where I glued the tach electronics (you'll see what I mean) All in all, its a VERY easy addition and looks great. Here's mine I did a few weeks ago.... |
02-22-2003, 08:10 PM | #3 |
Piston-
Didi you repaint the original needles? If so, what kind of paint did you use?
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
02-22-2003, 08:18 PM | #4 |
I need to repaint them all. They dont match lol. The Tach is original red. The other needles I used a Flouresant Orange from Krylon. Seems to show up very well in all light.
There is one thing I forgot to mention. You do have to trim some of the face of the tach and cut the backing to fit the cluster. I chose to just lay it into place, trim what I had to then use a hot glue gun to hold it in place. It's not going anywhere! BUT, here's what I wanted to warn you about, When you add the tach it will raise the printed circuit board aprox 3/8" and really strains it. It is possible to re-use a standard gauge type PCB but I strongly recommend buying a Gauge w/tach PCB. I just picked one up today at Chevy Duty and will be putting it on very soon. The only difference on the PCB's is there is a releaf cut out and extra material to compensate for the depth of the tach. |
02-22-2003, 08:19 PM | #5 |
how about the speedo has anybody put a late model speedo that goes up to 120 or higher
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
