lmc trim
anyone have a 76ish pic with the LMC trim? did it fit right? someone put my trim on with sheetmetal screws and pop rivets....
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
Happy to be here
![]() Join Date: Mar 2000
Re: lmc trim
I don't have any pics, but I did order a piece just to see what it looked like. I can tell you that it will not match your factory trim. If you want OEM trim there arent many options unless you chase down NOS sets. If your not too picky, it would be better than what you have.
Re: lmc trim
i'm looking for an entire nos set now! from what i've heard i don't think the lmc stuff is going to work for me. ..
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
Desert Rat
Re: lmc trim
I've searched far and wide for OEM style door trim. I found some for my 77 Cheyenne, do you have a pic of what you're looking for?
Happy to be here
Re: lmc trim
I suggest you order a piece and see for yourself. It isn't exactly like OEM in sheen and texture, but at least it all would match. I have a lot of NOS pieces and some of it doesn't match the others.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-23-2010 at 12:24 AM. |
Re: lmc trim
yeah i was planning on pulling all my OEM off since its got screws through it and then replacing it all with the LMC stuff so it all matches...
Re: lmc trim
I put the aftermarket trim on my truck.... the only piece that didnt work was the lower rear bedside pieces. I had to reuse my old pieces there. Also you will almost HAVE TO reuse as many of the OE clips off your old trim as you can. The new clips with the new trim either dont match each other or are just plain wrong. The stick on parts are fine, everything else it pot luck. I think they fit about as well as the stock stuff I had before and they look fine as long as you don't mix them with OE stuff. the back lower piece I had to reuse doesn't stick out though, maybe its because it's on the bottom at a good angle or something. Mainly they just look older than the new stuff but you have to look really close. I wouldn't have tried to mix and match the upper pieces though.
The trims ok, the clips are terrible! to me it would be worth it to go to a junkyard and rob the clips off of some junkyard crap trim. Last edited by 78 Chevyrado; 09-23-2010 at 04:55 PM. |
Re: lmc trim
Kenny,
it that a pic in your photobucket link??? the gray truck....
Re: lmc trim
My truck stuff is in the 78 c20 album.
heres the link. http://s160.photobucket.com/albums/t...2880/78%20C20/ |
Re: lmc trim
trim looks good from the pics....
Re: lmc trim
they arent exactly like the OE trim, some were longer or shorter than the OE stuff, but then again the oe stuff wasn't perfect either. Actually some of the aftermarket stuff fit better than the OE stuff as they were a bit "too long". I'm happy with them overall.
Dont want a large Farva
Re: lmc trim
PO converted my 74 to the 80's style trim. Ive actually been looking very hard at the entire LMC trim set. Ill keep an eye on this thread for a while before I invest.
Re: lmc trim
A lot of different stores sell trim kits... they are the same brand stuff. so buy the cheapest one you can find. I bought a kit from one store, it was missing some pieces (they arent actual kits but pieced together by the store) and bought the missing stuff from two other stores because i didnt want to wait and they all were the same brand and matched up perfectly.
Re: lmc trim
I forgot I had this.
Reply 187 on this page has my review of the aftermarket trim from when I put it on my truck. http://forum.73-87chevytrucks.com/sm...topic=9090.180 tip - reply 148 http://forum.73-87chevytrucks.com/sm...topic=9090.135 there is probably more trim stuff spread out in that thread, I don't remember exactly. |
