Old 07-22-2014, 01:06 PM   #1
47AD
One more question on power steering with solid axle
I thought I'd ask one more question about using power steering with a solid axle on my 47AD. I have read a lot of information on power steering options but was hoping to get some feed back from those who have used this type of kit:
http://www.ecklerstrucks.com/chevy-t...1955-1959.html
I've read tire rubbing, when turning full left or right, is possible if you go with too wide of a tire. Just looking for feedback on how these kits drive and feel and is the last thing I'm wondering about before I decide whether to keep the solid axle or not.
I have also seen pictures of the power steering kit that uses a Toyota Land Cruiser steering box but it would have an interference fit with the left side exhaust manifold when installing a SBC V8.
Dan
47AD is offline   Reply With Quote
Old 07-22-2014, 02:44 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: One more question on power steering with solid axle
What size tire are you trying to run?
Lowered with a dropped axle?
who's axle and steering arms?
Did you shim the axle to put the caster back into it?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 07-22-2014, 02:56 PM   #3
mr48chev
mr48chev's Avatar
It might be worth calling Ecklers and asking what wheel tire combos they suggest with that setup. If I were to run it I think I would wait to buy my wheels and tires until after I had it on the truck and working rather than buying them before. That is because wheel offset and or tire height/width may play a big factor in how they clear.
My ongoing truck projects:
Old 07-22-2014, 03:03 PM   #4
wolffcub
wolffcub's Avatar
I have the same kit. Easy install. Good fit with no rubbing. Just keep in mind about bump steer if you drop the truck later with lower leafs or an dropped axle. Im running 235's on 7" rims with a BS of 3.75"
wolffcub is offline   Reply With Quote
Old 07-22-2014, 03:07 PM   #5
wolffcub
wolffcub's Avatar
After I lowered the leafs I just had to flip the steering drag link to the top on one end and my bump steer went away.
Old 07-22-2014, 04:00 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Take a look at this.
http://www.chevyps.com/kits.html
look at the 55-59 truck section.
I did something similar on a 47 3800. It is very similar to the corvette steering from 62 - 83 also used on 63-67 Chevy C series trucks and a lot of late 50's 60's cars.
Old 07-22-2014, 05:06 PM   #7
47AD
I guess leaving out important details can make a difference If I keep the solid axle, I would be using Sid's 3" dropped axle and all the parts that go with it. Leaf springs would be new, made to stock measurements and ideally, 15" wheels. CPP has the same power steering kit and their instructions claim no wheel width wider than 7" and no backspacing more than 3.5". They also sell a pitman arm for lowered trucks which would also hopefully help with bumpsteer.
wolffcub,
How does the steering feel when you're driving your truck?
I haven't touched anything on the truck yet. I thought it would be better to ask questions first before I started making a plan on which way to go with it. I appreciate all of the advice and for all the quick responses.
Dan
Old 07-23-2014, 01:04 PM   #8
OrrieG
OrrieG's Avatar
I have been looking at this for a while trying to figure out now it works. Wouldn't the hydraulic part on the right end of the drag link need to be mounted to the frame to provide leverage to a ram to move the link? Or does it have an internal ram that extends the link??
Old 07-22-2014, 08:27 PM   #9
nvrdone
Ok, I'm looking at using a Toyota Land Crusier steering box, but I'm thinking about mounting it forward near the radiator support.
Right now I have a ' dropped I beam from Sid's. New king pins, tie rod & ends etc. Also added shims to bring it to 6 der caster. I have no bump steer and it tracks great at freeway speeds.
The only reason to add power steering would be to make it easier parking and slow speed turns.
After all, my kids tell me i'm older than dirt.
nvrdone is offline   Reply With Quote
Old 07-23-2014, 10:36 AM   #10
wolffcub
wolffcub's Avatar
The kit you posted a link to is the same kit that CPP sells. The CPP is the actual kit I got. I went thru 2 fluid reservoirs due to them being poorly made and leaking at the neck.
Old 07-23-2014, 01:32 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
It consists of a drag link that has a control valve and an assist cylinder and in the valve there is a shaft that goes against the pitman arm ball, it senses direction and force of the push or pull. That moves a shuttle valve that allows fluid to pass in one pipe of the other on a slave cylinder attached to the tie rod and one end to the axle pushing or pulling the tierod. I'm almost done with the one I'm doing and I'll post some better pictures
Old 07-23-2014, 03:01 PM   #12
OrrieG
OrrieG's Avatar
Ok now I understand, did not see the slave cylinder on the tie rod. Thanks.
Old 07-25-2014, 10:54 AM   #13
76er
Is that the same kit that uses the cpp400 or 500 series steering box that bolts to the stock location?
76er is offline   Reply With Quote
Old 07-25-2014, 06:14 PM   #14
roger55
roger55's Avatar
It's a 400 box and no one has mentioned that kit yet in this thread. I have the CPP 400 box installed in my truck. I haven't driven it out on the street yet but have around my property. So far, I think it's going to be great.
If you need details, check out my build thread. There are some considerations you have to deal with if you go this route.
roger55 is offline   Reply With Quote
Old 07-28-2014, 11:31 AM   #15
76er
Great, thanks i'll do that.
