Old 05-07-2007, 03:43 AM   #1
e rock
Anything worth keeping on a 71 350?
Well, the new motor is about to go in, and I'm just about done stripping all the necessary pieces off the old block before it goes to the scrapyard. #1 con rod brutalized the front of the pan (as well as some of the lower block from what I can see through the hole) before self-ejecting, so I'm pretty sure the piston siezed and the block is worthless. The damage was due to a lack of oil, but it was still running when I shut it down.
The stock heads are still intact and fine - are they worth keeping?
The stock intake is also intact, but one of the t-stat housing bolts siezed and broke off - is it worth the effort?
Stock 71 valve covers?
Anything else I should save?
Thanks,
Eric
e rock is offline   Reply With Quote
Old 05-07-2007, 09:50 AM   #2
Aarons72s
Re: Anything worth keeping on a 71 350?
Pics would help. But I would save the heads if they are still good. Nice to have an extra set around or you could trade or sell them or use them as cores. I wouldnt really bother with the intake. As for the valve covers, if they have a rubber plug for the oil filler than keep them. If it is the metal screw on filler plug chunk em. Just my thoughts.
Aarons72s is offline   Reply With Quote
Old 05-07-2007, 09:59 AM   #3
woodridge
woodridge's Avatar
If the intake is a 4bbl I would keep it. It would be a non EGR and the bolt can be removed. I would also keep the heads, they will have the big chambers but they will also be the heavy castings that are not as prone to crack.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 05-07-2007, 10:06 AM   #4
Overkill67
Overkill67 is offline   Reply With Quote
Old 05-07-2007, 01:23 PM   #5
396muncie
396muncie's Avatar
If it's a 4 bolt main, look at the main caps. If they have an "N"(Nodular) on them, keep them. Stronger and I had two different people ask me to trade for standard caps when I had my 71 350 rebuilt. I would junk the intake and heads...I see them at every swap meet for not much.
70 Custom/10, 396, Muncie 4spd, SWB SOLD
72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver
72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne
396muncie is offline   Reply With Quote
