Old 06-04-2006, 07:46 PM   #1
jkade
jkade's Avatar
Gas Guage Problem!! Help??
Went on a 100 + mile trip yesterday and my gas guage started messing up. I filled it up and it worked fine for a while and then it started moving around and going well over full. You can see in the pic how far over it has gone. What could it be???
Thanks In Advance, KadeName:  rhino 004.jpg
jkade is offline   Reply With Quote
Old 06-04-2006, 08:03 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Gas Guage Problem!! Help??
Looks to me like the sender wire is broken. The gauge is set up for 0ohm (empty) to 90ohm (full). If there is excessive resistance, i.e. wire broken or cut, the needle will peg, just like what you have there.
To test this, run yourself a long jumper wire from the back of the gauge to the output on the sender and turn on the key. If your needle goes back to normal- replace sender wiring.
If this does not work, maybe a bad gauge or sender, but they usually fail in the other direction (empty)
Try this and see where it gets you.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-04-2006, 08:07 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Also, the wire may have just vibrated loose from the post on the sender. This would explain it behaving erratically before failing. It is just a little 90 degree rubber boot that pushes onto a stud on top of the tank- kinda like a spark plug boot. Very easy for it to wiggle loose.
If this is the case, just crimp it with some pliers before pushing it back on.
-Chris
-Chris
Old 06-04-2006, 08:41 PM   #4
jkade
jkade's Avatar
-Chris
Can I get to it without dropping the tank?
Old 06-04-2006, 08:49 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, though it may be a pain with your truck dropped.
You should be able to reach above the tank, towards the front, on the passenger side.
Here's a pic as viewed from the front:
The large hole on top is where the sending unit is. The wire, i think, is towards the front of this.
-Chris
-Chris
Old 06-04-2006, 08:49 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Wow. The one I linked to wasn't as big...
-Chris
Old 06-04-2006, 08:55 PM   #7
Big Block
Big Block
Big Block's Avatar
If you check the voltage at the fuse block where the sending unit wire plugs in it should read around 9 volts. Just make sure if you replace the sending unit wire make sure you plug it back into the gas gage on fuse block. I accidentlly plugged it into constant 12 volt source and fried the sending unit and the wire. One expensive lesson learned.
Big Block is offline   Reply With Quote
Old 06-05-2006, 05:17 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good advice given, Thanks Gringoloco
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-05-2006, 06:42 PM   #9
jkade
jkade's Avatar
I appreciate all the info. I will let you know what I find.
Thanks, Kade
Old 06-06-2006, 01:11 PM   #10
Burt4x4
Burt4x4's Avatar
HighJack On:
Hmmmm interesting.
I stuffed my guge cluster with Autometer guages, except for the gas guage, speedo & dash lights, everything else is new...My gas guage does 'ping' past Full and stays there..I haven't had a chance to troubleshoot this yet but in the mean time I also lost ALL my dash lights...I ASSumed the whole guage cluster ran off 12v source so I connected EVERYTHING to 12v..
From your statement above, do you know if ONLY the gas guage needs the 9v or what??
HighJack Off:
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-06-2006, 12:23 AM   #11
boot85
71 Chevy
I had this same problem and tried a new wire and it worked,thanks
boot85 is offline   Reply With Quote
Old 06-06-2006, 11:43 AM   #12
2wdBlazer
The Blazer King
2wdBlazer's Avatar
My bet is the ground off the tank. Happened to me.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 06-06-2006, 07:42 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Good call. That would have the same effect.
-Chris
-Chris
Old 06-06-2006, 09:51 PM   #14
jkade
jkade's Avatar
I will give it a good looking over this weekend. I may have to change out the tank and get one with a in tank pump for the edelbrock pro-flo fuel injection that I bought to go on it.
Thanks for all the info, this is a great site.
Old 06-07-2006, 02:07 PM   #15
Burt4x4
Burt4x4's Avatar
FYI ~ my Pro-Flo setup works great with an external elec. fuel pump...that is the way it come from Edelbrock..I don't have a stock tank..I run NWMP 37 gal tank..duno if that matters..
Good Luck
Burt
Old 06-06-2006, 05:35 PM   #16
Big Block
Big Block
Big Block's Avatar
It will read 9 volts because of the resistor on the back of gas gauge. Same with the temperature guage. Everything else should have 12 volts. Hope that answers your question
Old 06-12-2006, 12:40 PM   #17
mburgert
mburgert's Avatar
Hey sorry to Hijack this one but i just reinstalled my cluster, and all the gauges work minus the temperature and gas I read above those two run off of 9 volt power but its just because of the resisters. They both all before, but the speedometer was doing the same thing as jkades. What could be wrong with the two (the needle doesnt move at all) and where is the ground from the gastank. Thanks guys
mburgert is offline   Reply With Quote
Old 06-12-2006, 06:57 PM   #18
Kantosensei
Not to hijack, but I replaced my sender and the guage goes a little past full, but it runs empty at a little under the halfway mark. Could that mean that my new sendeing unit was bent ???? I wish it was true that I was going that far on a half tank of gas, but its not the case.
Kantosensei is offline   Reply With Quote
