I havent purchased the kit yet for my 68, but I smoothed my firewall and I want to prepare the holes now, before i paint it... anyone know which size holes I'll need for the grommets?? I'm not using the plastic cover thing if you are lost.
any help would be appreciated! |
![]() Join Date: Jul 2010
Re: Firewall holes for Vintage Air
Smooth firewalls seem to look best with the bulkhead fittings available in lots of places. Here is the one that VA has in their catalog.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Thanks! but I was thinking about going with a bulkhead type fitting, but would it be possible to just use the "stock" equipment?
![]() Join Date: Aug 2013
I'm installing a vintage air unit right now. I also bought that square bulkhead
fitting but decided not to use it and go with the stock vertical unit, that came with my unit. The problem using the bulkhead unit is that you will have to make all new line inside and not that it's that big of a deal but I like the hard lines that came with the unit. I'll send a few tomorrow with the holes cut out. Here is a pic of what i'm about to cut |
#5 | |
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=614365 68 & I'll Owe You 1 ![]() |
new wiring harness. you have to cut the old hole out a hair but it fit perfect
when its done. |
Tony, Thanks man, how do you convert from the unit to the new lines under the dash?
well if you use the stock set up everything you need comes with it.
If you end up going with a block style you would have to make your own soft lines with AN fittings or custom hard lines. |
awesome, thanks! ...but....anyone know which size holes I'll need for the grommets??
Download the instruction sheet from VA website. The templates are in the manuals.
I did, only cout out sheets they have are the front dash pieces, I sent them an email. lets see what they got......?
I was just hoping somone had one laying around and could measure them, but no biggy. Thanks magicoolbus |
The V/A firewall block off plate is actually steel not plastic. Here's a pic of mine. More pics on my build thread.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
![]() Join Date: Nov 2004
That's good to know. The one on my C10 was plastic (that was 2006), but I noticed the firewall position/plates on the newer kits are different. I recently installed a new kit in my 65 mustang, but they don't need a block off plate. Mustangs used that big goofy under dash center unit so the firewall only had two holes for the heater core (the factory A/C lines are on the driver's side).
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#15 |
oh neat, my mistake. thanks for the update.
#16 |
Laid Back
![]() Join Date: Apr 2010
If you will pm your address I would be more than happy to send you a template...
Kyle
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#17 |
Tony, thanks, cut the old hole? Niiiicceee paint...what color is that?
#18 | |
In the photo he small line is 6 AN or 9/16 - 18 and the large ones are 8 AN or 3/4-16. You'll need a step drill to get the next size up for clearance for the threads which are the same on both sides of the bulkhead fitting I used.. |
#19 |
thanks guys! NIICCEE Fitz!
#20 |
The VA kit is awesome but doesn't provide grommets for the lower two lines. I just measured them and purchased two grommets from Lowes. Sorry I don't remember the diameter.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#21 |
Laid Back
The reason the bottom two holes do not have grommets is so the heater hoses can slide into the firewall and seal off the openings.. Which also allows for the heater hose clamps to be put inside the cab for a cleaner look.
#22 |
Aww grasshopper!
#23 |
![]() Join Date: Apr 2005
Old thread, but here's what I did...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#24 |
Hart Rod, That looks like what I would like to do. Can you explain how you made the connections from the A/C unit to the bulk head? I have a Vintage Air Gen 4 surefit and a inline Vintage Air bulk head plate. I thought I would have to discard the kit hard lines and make my own soft lines for in the cab between the bak head and A/C unit.
#25 | |
