Power Steering Pump Fit Question...
Folks, I'm in the process of re-assembling my L96. I ran into an unexpected fit issue when adding back my engine accessories. My power steering pump won't fit! More specifically, the reservoir needs to sit where the frame is
![]() Cutting and shaping the frame isn't an option. Has anyone else run into this issue? Wondering if anyone has ideas on a LS power steering pump with the same bracket mount that has a different shape reservior. I will need to craft two returns because I'm running hydroboost and want to use my power steering cooler... Last resort, I can cut and re-shape my reservior but I'd like to find something stock if possible in case it ever needs replacing. Thanks! |
Re: Power Steering Pump Fit Question...
What about the simpler old-fashioned-style steering pump/reservoir? Do a rockauto search for a 2010 tahoe with a 5.3. That's the steering pump I have. I've not installed the engine yet, but it looks a lot more compact than yours. The 2010 silverado 2500 with a 6.0 looks more similar to mine than to yours.
What's your l96 out of? Is it something other than a silverado 2500? Was it a van or other difficult to access vehicle that warranted that odd reservoir?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
![]() Join Date: Apr 2011
You could also try the PS pump that doesn’t have an integral reservoir, and mount a reservoir elsewhere. My LQ4 came from a van (ca. 2005) and the pump does not have a reservoir. I bought a metal bottle on eBay and mounted it on the firewall next to my hydroboost and plumbed it in there.
#4 | |
I'm running a hydroboost pump off of an 06 Yukon and it doesn't hang off that side of the accessory mount nearly at all. This would be my vote for simplicity. |
Thanks all for the great suggestions! The reservoir is out of a 2500 sierra 4X4 truck, nothing crazy. I double-checked and the new pump/reservoir that I have is, in fact, the correct stock replacement.
I have considered running a separate remote reservoir, but I will check into the 2010 5.3, 2006 and Volvo options as well. I'd like to find something that at least fits the accessories mount I have now. I've got enough customized craziness going on in other places on the build so I'm trying to work stock replacement pieces where ever I can for simplicity and ease of maintenance's sake. I guess that's what pissed me off so much about the stupid pump not fitting! |
Delete it entirely, re-route the belt and run a Volvo electronic power steering pump. Pick a part price is about $40. Problem solved.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
I bought a reservoir off of ebay for my PS pump. It attaches to the alternator/PS bracket with an over-center Southco clamp
The pump itself has a -10 JIC/AN fitting pressed into the return port Here's what it looks like on the engine |
Hey rowdy, what did you ever figure out with this?
69 C10 fleetside long bed - 6.0/4l80E in progress |
I settled on a remote reservoir setup similar to E01. I press fitted an AN firing on my pump and fitted a PSC reservoir rat accommodates my hydro boost. I still have to finish the plumbing but reservoir is mounted on my alternator accessories bracket on a custom pedistal I fabricated myself.
Posted via Mobile Device |
