Factory bucket seat question
My 71 has original truck buckets, and they are factory not just an addition as the cab has all the correct bracing and stuff under the floor and they are listed on the SPID. My question is did all of the trucks that were factory equipped with buckets have the carpet to cover the fuel tank? Mine does not appear to have any holes in the back to screw the carpet to. It did have the cardboad fuel tank cover but that is it. Does anyone re make those little stainless trim rings that hold the carpet on?
![]() Join Date: Feb 2001
Re: Factory bucket seat question
I will take a stab at this.
I'm guessing the carpet covered gas tank came in a Trim package and the Buckets alone did not come with the carpeted gas tank. Others? ![]() Posted via Mobile Device
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
![]() Join Date: May 2010
The bucket seat option was to include seats, console and "floor carpeting". The assembly manual also shows the tank carpet.
The trim rings (generally referred to on the forum as clips) really aren't necessary and are fairly hard to come by. The do show up in the parts section occasionally. You could get by with fender washers or by using a continuous strip of some sort (something like aluminum yardsticks) under the top edge of the carpet since the carpet is folded down over it anyway. In my opinion, a strip works better since it prevents sagging between the attachment points. Unless, of course, you are doing a factory correct restoration. |
#4 | |
My main question is, did all of them have the carpet? I assume they did. It is weird mine has no holes. I don't care that it doesn't, I will drill some and make a strip to help retain the carpet I just couldn't believe a factory bucket seat truck would not have that carpet. |
#5 | |
Another point is the years varied to the Trim packages. Ie: the 67cst trucks came with buckets while later years the buckets were optional in later years. I guess I would like to know...did buckets come as a separate package in 1971 and what package did the carpeted gas tanks come in?
#7 | |
Still Learning
1971 Custom/10 K10 350,th350/np205,3.07 posi,towhooks,Factory buckets and console,AM-FM |
Moderator
![]() Join Date: May 2007
I have a gas tank carpet made by Trim Parts, bought from Brothers. It has plastic "hooks" (more like flaps) that hook over the top of the tank to secure it...doesn't even need screws. I am not sure if all the bucket seat trucks came with carpet or not...I would think they would have?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Still Learning
The screw trim rings are made from brass.
borrowed pics from this site |
