Old 10-30-2012, 12:18 AM   #1
pestwagon
help please E-brake cable instructions needed!
I bought 1 front and 2 rear brake cables (one for each rear brake backing plate) as such:
Front cable:
http://www.ebay.com/itm/320772915004...84.m1497.l2649
2 rear cables:
http://www.ebay.com/itm/380499878317...84.m1497.l2649
Question: How are these attached? My truck has NO E Brake cables!!! Oh it's a 1964 Fleetside shortbed Chevy.
pestwagon is offline   Reply With Quote
Old 10-30-2012, 12:38 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: help please E-brake cable instructions needed!
Hope this makes more sense than my explanation.
LT1 Burb is offline   Reply With Quote
Old 10-30-2012, 01:18 AM   #3
pestwagon
Does the 1964 C10 transmission cross member have that type of lever system on it originally? The previous owner had a TH350 transmission swap done in place of the original granny 4-speed on the floor. I see 2 bolt holes on the crossmember where one of the brackets would have mounted...couldnt see the other side too well under the truck tonight.
It appears as if my 2 crossmember brackets and lever system circled above is missing in action because the swapped in TH350 tranny was to big to allow the Ebrake center lever system to still be there.
Anyone else have this problem...and what did you do to remedy it?
Old 10-30-2012, 01:40 AM   #4
pestwagon
Looks like this was one solution: similar to a GM A body answer...run a cable from one rear cable to the other rear cable and pull it foward with a similar setup
Old 10-30-2012, 09:21 AM   #5
kieth
kieth's Avatar
Here is a shot of a 66 gmc that shows the later model e brake system since your truck is not stock. Kieth
http://kieth.smugmug.com/Trucks/66-G...4459&k=jGXPbLB
kieth is offline   Reply With Quote
Old 10-30-2012, 09:49 AM   #6
pestwagon
Keith what year trucks have that "later model e brake system"?
Old 10-30-2012, 08:53 PM   #7
joeld
There is a very good write-up on this subject in the FAQ for the 60-66 section. I'm going thru the same thing right now, and this info was just what I had been looking for.
And also, thanks kieth for posting those pictures! I finally see how that long rod connects to the cable.
Joel
joeld is offline   Reply With Quote
Old 10-30-2012, 11:41 PM   #8
pestwagon
Joel
Joel I couldnt find the thread that referenced to the rear cables in that section. Can you show me the thread? Thanks...
Old 10-31-2012, 09:13 AM   #9
kieth
kieth's Avatar
1966
Old 10-31-2012, 09:56 AM   #10
joeld
Here it is.
Joel
http://67-72chevytrucks.com/vboard/s...d.php?t=527022
Old 10-30-2012, 09:20 AM   #11
LT1 Burb
LT1 Burb's Avatar
That's the 66 setup shown there but I don't think those rear cables you have will work with that setup. It's probably what you will have to go too, that is what is on my suburban and I have a 700R4 with an ECE crossmember.
