Old 07-10-2009, 10:00 PM   #1
OvertimeRide
88 4x4 shell on a 77 2x4 chassis
Does anyone know if a 88 4x4 K5 blazer shell will fit in a 77 2x4 K5 blazer chassis.
OvertimeRide is offline   Reply With Quote
Old 07-11-2009, 10:35 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: 88 4x4 shell on a 77 2x4 chassis
I think the 77 frame is a little different. I believe 78 they changed the frame so 78-91 should work...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-11-2009, 07:42 PM   #3
scruffre
scruffre's Avatar
Mine is a 88 body on a 78 frame.
Dave
scruffre is offline   Reply With Quote
Old 07-11-2009, 08:09 PM   #4
OvertimeRide
Thanks guys but I'm not really sure my question has been answered. I need specifics on what is different and what problems I might come accross. What is the difference between a 77 and 78 frame?
Old 07-11-2009, 11:31 PM   #5
USSkoval
The floor from behind the front seats on back is different. '78 was the start of a dropped foot well for the rear seat passengers. The body mounts in that area are in completely different spot, and I think the rails are also contoured a bit different. It can and has been done, but there is fabrication involved.
USSkoval is offline   Reply With Quote
Old 07-12-2009, 10:09 AM   #6
OvertimeRide
I really appreciate all the comments so far. I'm pretty confident I can fix it. What is the Texas Heatwave by the way?
Old 07-11-2009, 11:28 PM   #7
72 CustomCamper
huh ???
Counting from the front. The 3rd set of body mounts back are different. On 73-80 they mount on the inside of the frame. On 81-91 they mount outside the frame.
http://www.lmctruck.com/icatalog/bzc/full.aspx?Page=22
Old 07-13-2009, 02:09 AM   #8
BLOWN73
you may want to check to see if the frame of the 77 is going to interfear with the floor of your body.
BLOWN73 is offline   Reply With Quote
Old 07-13-2009, 08:50 PM   #9
OvertimeRide
Looks like my only option is to fab in some channels right behind the seats where the rear floor pan will come into contact with the frame. Then fab some cab mounts for the outside of the frame since I already have a completely rust free 88 shell.
