Still Learning
WTB 2-1/2-3" drop spindles, L. control, Rear spring mount Xmember
I am looking for some parts for my 69 project. 2.5-3" Drop spindles if you have extra set? Pass. side lower control arm and rear spring mount cross member. here are some pics of what I need:
Pass side Lower control arm FOUND AT PULL A PART 12-5-10 ![]() ![]() Still need thisCross member: ![]()
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 12-12-2010 at 11:56 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: WTB 2-1/2-3" drop spindles, L. control, Rear spring mount Xmember
Mike,... I have a crossmember section on one of my parts trucks (upper shock mounts have been removed),... if you can't find one closer.
I could just sawzall off the frame section. I can look at it tomorrow,... but I think shipping might kill the deal.
I also have a pair of "rubber bushed" 73-87 lower a-arms,... but shipping would definitely be crazy.
Still Learning
Thanks Keith! take a look at what you have. It might not be too bad to ship snail mail or ups? I know I have some of the cross members out there in my stash, just don't want to cut up a complete frame. I know I don't have any control arms. I only need one, how hard is it to remove the mounting shaft? I bet that there is a bunch of weight in that part.
The a-arms cross shafts are different.
The cross shafts are specific to either 67-72 or 73-87. I'll try to take a few pics of the crossmember tomorrow.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-29-2010 at 12:52 AM. |
Still Learning
I am taking this bent one to work tomorrow, maybe I can heat it up and straighten it? Thanks for looking for me.
![]() Join Date: Aug 2004
I have the lowers and uppers from a 72, if your interested.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Still Learning
Clyde,
I really only need the passenger side lower. Will you seperate it? how much? Shipping will probably kill the deal for the set.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 11-29-2010 at 12:23 PM. |
I dont really need them....so whatever you think plus the ride....I dont know if I can do it that way, let me know mods if that is a no no.
Do you need a set of stock upper shock mounts?
(I might still have a set) Or are you going to use a set of rear shock relocators?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-30-2010 at 09:44 AM. |
#11 | |
Still Learning
Also, I just found out through some research that it looks like the rh control arm I'm looking for is the same on the square bodies. So I should be able to pick one up at pull a part pretty cheap. |
#12 | |
ECE, POL, CPP all sell them. You can run up to a 6" rear drop coil without a c-notch. Nate (72BlckButy) has a 6" rear drop with no c-notch,... and it's fine.
#13 | |
'69 Chevy SWB
![]() Join Date: Feb 2009
With that much rear drop you'll definitely want to run rear shock relocators.
As far as the lower A-arm, I'm not sure, Keith is the right guy to be asking. Wish I could help you out more.
Matt ![]() ![]() ![]() ![]() ![]() '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
Yes,... the 73-87 (squarebody) a-arms will bolt right on.
The lower ball joint will have to match the year spindle you are using. (63-70, 71-87)
#15 | |
Still Learning
Thanks for the info on Nate's truck, I really like the height on it too. Still haven't had time to remove the old cross member yet. I really think I need to find it local because of the weight. |
#16 |
I just bought the same crossmember for my son's 69 project. The weight on the box was 24 lbs. and shipping from Florence S.C. to right out side of Atlanta Ga. was $25.00. Hope this helps.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#17 |
Still Learning
Thanks for the info Greg65. I was able to pull the cross member today and weigh it. It weighs right at 15lbs with the frame piece it will be closer to 25lb. Keith, can you see how much it would cost to ship it from your place to 74851 OK? Thanks.
#18 |
Still Learning
Here is what it looked like on the under side. Trashed!
#19 |
My zip code is 65251.
I use UPS. It might be a few days before I can get to it. It's 4* here and it's covered in snow. You will need to add the length (and weight) of the two frame rail sections also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-13-2010 at 05:40 AM. |
#20 |
Mike,... I think teeitup has your shock crossmember.
Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=437429
#21 | |
Still Learning
I already paid $20 for the upper shock mounts so I don't need them now. Thanks for looking out for me. I have a few of them but really don't want to seperate them from the frames. I was hoping to find one already out and ready to go if you know what I mean. If I have to, I will break down and pay up, but I'm as tight as they come right now with Christmas bills rolling in......13 and 16 year old OUCH. |
