haha, ford guys...
stock psi for mech. fuel pump?
can some one tell me how many psi the stock mechanical fuel pump makes on a non computer controlled 1/2T 350?
Re: stock psi for mech. fuel pump?
They vary but it should between between 5-7 psi. some lower some higher.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
The One And Only !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
haha, ford guys...
really? i figured it to be higher? 7only huh?
Yep 7 lbs, That's the max pressure on the Demon carb sitting on my 502. Much over that will result in running rich/flooding.....
#6 | |
![]() im just jealous Last edited by diponyou; 02-21-2010 at 11:53 PM. |
Sorry, I only mentioned it to use as reference to even a big block runs low fuel pressures as well.
If ya believe that one I'll tell ya another..... ![]()
ahahahaha
haha, ford guys...
awesome, thanks guys!
The fuel pressure has nothing to do with the engine size. Carburetors cannot handle more than 7psi in most cases because it will push the needles off the seat and flood the carb. The only exception would be spring loaded needles and seats used in off road and race carbs but even they will get pushed open with fuel pressure too high. Edelbrocks are finnicky too they dont like more than 5.5psi or they will run rich at idle.
