01-24-2010, 03:11 PM | #1 |
Anyone running a RamJet 350?
Curious if anyone on here is using this crate engine.
I am encountering some odd problems with it and am in search of others solutions. |
01-24-2010, 03:17 PM | #2 |
Next project: 1970 K10
Re: Anyone running a RamJet 350?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-24-2010 at 03:19 PM. |
01-24-2010, 07:43 PM | #3 |
Thanks for the link, although I am trying to find others who drive these on a more regular basis.
I have some specific questions regarding some sensor values and am curious of what altitudes people are running these at. |
01-24-2010, 08:19 PM | #4 |
i've got one in the crate at the shop now, we are going to put it in a 64 with a tremec 5 speed. I will post pics on my site,www.jmcautoworx.com
05-08-2012, 08:48 PM | #5 | |
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
01-24-2010, 08:53 PM | #6 | |
There used to be a Cartoon when I was a Kid called "Roger Ramjet". Being as my 1st name IS Roger, ewverone always used to call me that! My Dad always called me "Leo Nomillini" (sp), miss him everyday. (Back to your Regular Programing)
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
01-24-2010, 09:28 PM | #7 |
gets board easy.......
the ramjet uses off the shelf GM sensors. What issues are you having?
01-25-2010, 12:07 AM | #8 |
The major problems I am having are with the MAP and O2 sensors. The MAP will continually throw the DTC 34 Low Voltage warning. The 02 sensor will eventually stop outputting a voltage signal. Replacement sensors have been used in both applications. The replacement sensors were an attempt to bring the computer back within operating parameters. The engine ran better but was still showing signs of an inability to run a normal pulse width.
Per the shop, it looks like the engine thinks it is at sea level and the 02 sensor can only correct 20% towards leaning it back out. Overall the engine is rather lean at idle and overly rich at part throttle. Current plan is to change the gain values of the sensor and create a custom fuel and spark curve. Just curious if anyone else has encountered any issues with this engine and application. |
01-25-2010, 02:34 AM | #9 |
My 2 cents, make sure are getting the correct 5V ref , Signal and - to MAP....and those values are getting to computer terminal.
04-29-2012, 04:51 PM | #10 |
I know this post is over 2 years old but heres my 2 cents. I know GM came out with an updated ECU, I believe it is the 4th generation ECU for this motor and perhaps they have worked out the kinks. Check with a GM Parts Dealer?
