What Do I Need
I HAVE A 1960 CHEVY 1/2 TON P/U I WOULD LIKE TO PUT FRONT DISC BRAKES ON IT i WOULD LIKE TO DO FROM SCRATCH ( NOT USING A KIT)
WHAT SPINDLES WILL FIT THE 60 AND WHAT ALL WOULD I NEED |
The easiest way to do spindles is just do get ECE. Youi can get them in stock height or 2.5" dropped. It is the easiest way really, and the quality is top notch. If you get their spindles, everything from a 73-87 chevy will bolt on. rotors, calipers, bearings. I got some braided stainless lines from cpp.
I dont know if you want to do power brakes, but if you buy a power booster kit, and you have the clutch master that is one with the brake master, then you will have to cut a piece out of your firewall and weld in a plate with a new hole.
62 c10 short fleet 350/350 dropped 87 toy: SAS 35" MT/R's, 5.29's, detroit rear, exocage |
