12-08-2008, 10:21 PM | #1 |
1947-1959 chevrolet 3/4 ton spindles
I heard that 1947-1959 chevrolet 3/4 ton spindles will mount on a 1946 chevrolet truck. So I can run disk brakes on the front axle.
03-12-2009, 12:00 AM | #2 |
KOFFIN DRAGGER
Re: 1947-1959 chevrolet 3/4 ton spindles
Wow, no replies? I am in the process of doing this same project. I will keep you posted and give you a parts list once I make it all work together.
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
03-12-2009, 11:54 AM | #3 |
do you mean 1/2 ton instead of 3/4 ton? there are no brake kits for the 3/4 ton trucks, unless you make your own, but there kits for the 1/2 ton. In fact I swapped out the 3/4 axle front axle for a 1/2 so I can run a 5x4.75 disc brake kit. From what I've been told the axles are the same from 41-59, or at least the disc brake kits work for all those years, with only 1 difference.....when they switched to bendix brakes the lower hole on the spindle ears were enlarged from 7/16" to 1/2".
Hope this helps some
Chris 52 Chevy 3600 (3/4 ton) 5 window pickup -54 235 Inline 6 w/ Fuel Injection Conversion -Clifford 2/4bbl Aluminum Intake and Headers -1/2 ton front axle swap w/ 5lug disc brake kit -CPP Power Steering Kit Various pictures of my 52 Chevy 3600 |
03-12-2009, 12:25 PM | #4 |
Hollister Road Co.
41-54 are the same axle 55-59 are the same. The spindles are close enough for the disc kits on 41 -59
