03-29-2005, 11:14 PM | #1 |
Listening since '86
Changing a clutch - questions!!
Hey guys,
well the inevitable has started to happen, my clutch is slipping, and I need to get it replaced. Given, i've only checked with one place so far, but they quoted $817.00 (Cdn dollars) and that included a new clutch, machining work, and approx 5 hours labor. Does that sound about right? The guy was laughing and saying that they don't usually change clutches on many 71's! Hey can't remember if it has a crossmember so he factored that into the price quote above. I was quoted a price of 275.00 (Cdn) for the clutch parts only, from a parts store, but have never changed a clutch. Christ, $817.00 is more that I paid for the whole truck, so I'm almost ready to push the sucker into the lake!! Especially with these gas prices.
2007 Saturn Aura - hey it WAS a GM product |
03-29-2005, 11:18 PM | #2 |
Got Light Emitting Diode?
i was quoted 450 (US) for mine. i had never changed one before either, i just read the book and got an extra set of hands. the 3 speed would probably be alot easier than a 4 speed just cause of the weight factor.
edith yeah i had 130 in parts too
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
03-29-2005, 11:37 PM | #3 |
Questionable
My 3spd (for a 10" clutch, inline 6) cost $160 for pressure plate, clutch, bearing and everything else. Took me about 1 hour to install with two friends and a cherry picker to pull the engine. I don't know if it's normal to need to pull the engine, but I had to pull it anyways, so ...
I don't know what the 350 is like, so don't listen to me
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-29-2005, 11:41 PM | #4 |
but how long did it take to pull the engine??? it would be easier to do from underneath. hope its not lowered
03-29-2005, 11:50 PM | #5 |
Listening since '86
No, my truck is not lowered, but does sit low enough that dropping the tranny might be tricky.
03-29-2005, 11:54 PM | #6 | |
Questionable
03-29-2005, 11:54 PM | #7 |
the 3 speeds are alot lighter than a 4 speed. i had to use a jack to lower it down. you might be able to let the 3 speed down on your chest then on the ground
03-29-2005, 11:55 PM | #8 |
with the hood on?
03-30-2005, 12:02 AM | #9 | |
Questionable
03-30-2005, 12:01 AM | #10 |
Joe, What kind of machining do they have to do? Which shop did you bring it to? Mine has to be replaced pretty soon as well, Doug
Forget about the machining ? I was thinking of something else. Last edited by 69 Short Fleet; 03-30-2005 at 12:53 AM. Reason: Was thinking of something else |
03-30-2005, 11:34 PM | #11 | |
Listening since '86
03-30-2005, 11:52 PM | #12 |
Listening since '86
well holy crap guys, thanks for all the help!!! The above post was made without even finishing reading the whole post.
After reading all of your posts, I might just do it myself. again, thanks
03-30-2005, 12:02 AM | #13 |
you should only have to have the flywheel surfaced
03-30-2005, 12:14 AM | #14 |
changing a clutch on one of those is easy as hell. i would rather do 20 of them in place of the one in my s10. in reality the fly wheel only needs to be machined if there are heat marks on the fly wheel but for the most part you can get away with roughing up the surface with some sand paper and bolting it back on
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 C30 flatbed dually 1970 C10 longbed stepside (in pieces) 1976 Dodge Dart 1963 Dodge Dart |
03-30-2005, 12:24 AM | #15 |
Sisyphus was my mentor!
I changed my clutch myself last summer & it was easy & cheap - I got a 12" (i know I dont need a 12" but an 11" clutch was 160 so for 15 more bucks I got a killer clutch) OEM clutch (throwoutbearing, friction disc, pressureplate & alignment tool) for diesel GMC's for 175CDN from a local clutch shop & they ground my flywheel for that too, but it took 2 days & while I was there, I changed the rear main seal as well. I have a L-6 & a three-on-the-tree. steps are roughly as follows:
driveshaft out unhook speedo & shifter & tranny out remove dustcover from bottom of bellhousing & remove ballstud for clutchfork unbolt pressureplate from flywheel & drop it & the friction disc out unbolt the flywheel & get it ground at a clutch place install is reverse but you gotta have a pilotshaft to hold the friction disc inplace while you evenly tightenup the pressureplate install clutchfork on ballstud & install throwout bearing the hardest part is getting the transmission back onto the bellhousing & into the frictiondisc & the pilotbearing.. I bought the two longest bolts in the same thread as the bolts that hold the trans on & i threaded them into the upper holes. this gave me a "rail" to slide the trans home on. reinstall dustcover, hook up shifter, speedo & driveshaft. oh ya, I had no jack so it was all muskle!
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
03-30-2005, 12:39 AM | #16 |
Registered Cruiser
It's not that tough of a job, but if you could get someone to help you that has a little experience would be good. There is no crossmember, and the bell housing doesn't have to be removed from the engine block. If the transmission is slid back from the bell housing the clutch can be removed from the bottom.
After you're up on jackstands, and the battery's disconnected you'll have to remove the starter, and dustcover. Next disconnect the carrier bearing, then remove the driveshaft from the rear end. Mark it so that it will go back together exactly the same, and wrap tape around the U-joint so that it doesn't come apart. disconnect the shift linkage. Don't lose the clips and springs. You'll probably find some broken bushings. The plastic is crap so replace them all with bronze. The ones I use are Mr. Gasket. They come with new springs and clips too. Remove the speedo cable. Disconnect the clutch linkage. At this point the trans is ready to come out. after removing the four transmission bolts it can be slid back. A transmission jack comes in really handy, but the armstrong method also works well. I leave the driveshaft in the tranny just because it makes less of a mess. With the trans moved back slide off the throwout bearing, and snap the arm off of the ball pivot. remove the six bolts holding the pressure plate to the flywheel, and the whole assembly will slip out the bottom. Carefully inspect the flywheel. Be aware of hot spots, and tiny cracks. If you don't like the look of yours consider having it turned, or buying a remanufactured unit. Your clutch kit should come with a new pilot bushing, clutch disk, release bearing, and pressure plate You will need a clutch alignment tool. The clutch kit I bought the other day came with one. Try to keep your greasy by now hands off the clutch contact surfaces. removing the pilot bushing requires a special tool. I don't know what it's like in the great white north, but the chain stores have loaners here. When you re-assemble be certain to lube everything. Take special care in making sure the disk is aligned properly. Good Luck
I intend to live forever. So far, so good. |
03-30-2005, 01:47 AM | #17 |
If it helps you to see instead of explain, there is an article on it in this months issue of Classic trucks.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
03-30-2005, 01:17 PM | #18 | |
Questionable
03-30-2005, 09:13 AM | #19 |
If it's an original 4 speed, shop around for a better price as doing it yourself without a lift of transmission jack can be a PITA. A 3 speed is really a simple easy deal and one you can tackle. Shouldn't take but a couple of hours and is straight forward. The only reason I say the 4 speed is a PITA is because it is one heavy SOB and not fun to do as it doesn't balance on a jack easy, you got to pull the shifter, and realigning it to the disc can be a major effort if doing your self. Would think you should be able to get a done price for around $400. Parts should be under $150.
03-30-2005, 09:57 AM | #20 |
It's not to difficult to do and when I was younger seemed like I was doing at least 1 a week with no jack! Nowadays if I can avoid it I will... when I got my truck it needed a clutch and I was quoted ~$700.00 ! BUT the "mechanic" told me that was a rough estimate and most likely it would be more ! He told me parts alone were $400.00...
I checked and the most expensive NEW parts were only $180.00 retail so I got to thinkin(ouch!)... I plan on keeping my truck forever sooooooooo... now it's an automatic! I bought a TH 350 for less than $300.00 built to my specs with a converter. Any how if you are up for it it's not bad and a good learning experience. Even if it's the first time you've done it as long as you have the tools and ambition take a weekend and give it a shot. Shop around for parts and for what it cost go ahead and get the flywheel machined since it'll save you "guessing" the condition it's in. |
03-30-2005, 10:30 AM | #21 |
fixer of 72 GMC LWB
while you have the tranny out replace the rear seal of the tranny and put in new fluid... 305 yrs old I am pretty sure they'll need to be replaced... BTW- as said earlier if the plate looks good roughing it up would be enuff
Good luck...3 spd weighs about 75 pounds so its an easier one to do... |
03-30-2005, 10:34 AM | #22 |
Beer Power!!!!!!!!!!
Job is easy, you can "bench press" the 3 speed on and off of the bell housing. If you find that you cannot get the tranny back in after changing the clutch and pressure plate, have a freind go inside the cab and mash on the clutch pedal. Worked for me.
Rather be fishin' |
03-30-2005, 08:03 PM | #23 |
the 4 speed isnt that hard either. it is harder to lift but its pretty much the same ****
03-30-2005, 10:09 PM | #24 |
Where's my beer?
Shifty, no it's the May issue. It may not be on the shelves yet, I just got it in the mail I think last week. It's an article on their in house I think 68, switching from a 3 on the tree to floor shift and touches on clutch replacement also.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
03-30-2005, 11:47 PM | #25 |
Designated A-hole!
Here's a tip for any tranny install. Buy two long starter bolts and sut the heads off, grind a flat surface (something for pliers to grip) and screw them into the bottom bellhousing bolt holes. It's a lot easier to stab the tranny onto these two bolts and you don't have to hold it up while you start a bolt.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
