Old 12-17-2011, 05:40 PM   #1
gottattooz
gottattooz's Avatar
Rust in gas tank
I've got rust in my gas tank (behind the seat). I bought one on craigslist, and it was worse than the one I had originally. So, how can I go about cleaning the rust out of the gas tank?? I can't afford a $300-500 under the bed tank yet, so I"m trying to make do with what I have.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 12-17-2011, 07:06 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Rust in gas tank
Hirsch makes a gas tank sealer. Hot Rod magazine did a story a bunch of years ago about getting the rust out of an older tank. Pull the sending unit out of it and put a handful of rocks into the tank. Then, shake the tank and rattle it till you're deaf. Use some kind of solvent to wash out the rust that is loosened by the rocks and pour it all out. When it is dry, seal it with the Hirsch material.
Oh, my son-in-law (one of them) lives in ZHills....with my daughter and their kids. Nice area.
Member Nr. 2770
Old 12-19-2011, 04:40 PM   #3
specialtyretail
So,, what else you got???
specialtyretail's Avatar
In the old days, we would get all the gas out. get a couple of handfulls of good white chat gravel, several gallons of laquer thinner. Put everything in the tank, seal up all outlets, strap it down in the bed of your old farm/work truck and go cruising the gravel roads, doing whatever you do while cruising gravel roads. Nothing like a nice long drive to help clean parts.
specialtyretail is offline   Reply With Quote
Old 12-19-2011, 05:11 PM   #4
Fitz
-Josh
Go down to your local Home Depot and buy a gallon of Muriatic Acid. it's in the swimming pool chemicals part of the garden shop. Pour the whole thing into your tank and slosh it around for a half hour or so. It will dissolve all of the rust and none of the good metal. Pour the crap back into the gallon jug and dispose of it then use the Hirsch tank sealer everybody around here likes after waiting a day for the tank to dry out.
Fitz is offline   Reply With Quote
Old 12-20-2011, 03:59 AM   #5
gottattooz
gottattooz's Avatar
Thanks for the help.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-20-2011, 05:46 AM   #6
The_BullDog
The_BullDog's Avatar
check out POR15 they make an awesome tank kit. I havnt used it myself but acouple friends have and said its great. cleans the tank then seals it and binds to the rust
The_BullDog is offline   Reply With Quote
Old 12-20-2011, 07:54 AM   #7
cdowns
cdowns's Avatar
the muriatic acid works real well// but b4 using it i'd use a pressure washer first to get as much loose stuff out prior to the acid to get beast results
i've used the POR15 stuff it was excellent, my local autopaint supply store has it in stock or if you go to sumpter swapmeets there is usually a guy selling it there either of those places you wont need to pay shipping
Old 01-09-2012, 05:51 PM   #8
westgl
westgl's Avatar
ONLY use Muriatic acid as an absolute LAST RESORT.
It works but if the condition of your tank is not so good it can do more harm than good, by removing to much metal especially if there is a rusty thin spot.
I would take it to your local Radiator shop, they do Gas tanks too, let them soak it for a couple of days they will pressure check and clean out the lines. for less then $50.00.
i have taken several Gas Tanks in to the radiator guy, if it is bad shape, they tell you it's bad and they wont charge you anything.
They can coat your tank for you too.
Then you dont have to deal with the Chem's
maybe this is another solution
westgl is offline   Reply With Quote
Old 01-09-2012, 06:15 PM   #9
KEL
72 GMC
KEL's Avatar
closer to home . . .
http://67-72chevytrucks.com/vboard/s...d.php?t=487721
KEL is offline   Reply With Quote
Old 01-09-2012, 08:55 PM   #10
midniteblues
midniteblues's Avatar
so with all this input about sealing the tank with these kits isnt that kinda like a bandaid ...they have radiator sealers too we know how they work. what about just getting a new one?they are not that much imo.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
