![]() Join Date: Jan 2002
steering arm 72 blazer
Does anyone have any tricks for removing the steering arm off a 4wd.it went smooth until time to remove the arm itself and i couldnt get those three washers off it started raining on me so i quit for tonight it looked as though the washers were snap rings for safety but i looked in the service manual and it didnt even mention them it just said to replace the nuts anyones help would be apreciated THANKS DAVE
1972BLAZER,1966C10SWB,1963NOVASS HOLIDAY,IL |
huh ???
Those washers are a real B!)$h to get off. They are tappered. You could try a hammer and tap upwards to loosed them. It's been a while since I've messed with them...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Thanks Chuck
I bought some good penetrating oil today so i think ill soakem awhile DAVE
Too many is never enough!
conicle washers
The conicle washers can be a pain but nothing a BFH won't cure. I was a little sceptacle when my mechanic buddy showed me how to do it but worked like a champ. Get a good size hammer, like a mini sledge, and give a couple of good hits to the side of the arm in the area of the washers. This will break the washers loose and the arm will lift right off. Don't be shy! You won't hurt anything unless you miss! Good luck.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
