04-26-2016, 10:51 PM | #1 |
Suggestions on how to upholstery door panels?
Hey everyone, I want to have some fun with upholstering my 63' door panels myself. I saw that spraying adhesive and wrapping them with vynil works, using a heat gun, does that help getting the contours to stay on the lines shapes of the panel? How is that done? Also, where do you get vynil at?
Any suggestion and designs would be awesome, I want to go with a factory look, I was getting inspired looking at corvette interiors. thanks for reading and commenting! |
04-26-2016, 10:53 PM | #2 |
Re: Suggestions on how to upholstery door panels?
@fatluckys Sean Johnstun door panels are amazing
04-26-2016, 11:27 PM | #3 |
04-27-2016, 01:59 AM | #4 |
meowMEOWmeowMEOW
I did mine in a simple vinyl/leather wrap to match my seats, and made a very basic lower door panel wrapped the same way w/matching hardware. I have pics in my build, and honestly it was fairly easy if your not aiming to "Build" your own style panel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-28-2016, 09:39 AM | #5 |
Local guy took pleated vinyl over 1/4 plywood to make mine. Drilled the stock tins to allow 1/4" self-tapping screw mounting from the back side.
Re-pop arm rests with beige painted white - re-pop zinc and clear door panel screws cheap single stage enamel white paint Cheap and easy... I'm happy |
04-28-2016, 10:16 AM | #6 |
It's Better With Nitro
Since I never liked the original arm rest/door pull (stretched the deform the inner door panel since the previous owner never adjusted the door to close properly), Ron Mangus helped me with building out some structure out of wood and foam to replace the original arm rest. Then covered it in leather with contact cement. It took a couple of days to relax the leather.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
04-28-2016, 10:32 AM | #7 |
I don't know if the 63's have the same raised center section as the 61's but I agree with one of the previous posters in that I never really liked the shape of the earlier door panels.
I have been covering interior panels for almost 20 years and the best material that I have used is Katzkin Vinyl. It will be just as good in 20 years (and better then leather because leather tends to crack) and it has excellent texture on the surface...unlike some of the cheaper vinyls. Looks just like their leather products. Plus, it is cheap and you can get it in about 30 different colors. SAR (online store has it for about $22 to $25 a yard). You could probably get by with about 3 yards. For adhesive, I would not use the spray can variety. There has to be some upholstery supply stores around you that will sell you a vinyl top adhesive by the gallon (the darkish yellow glue). Probably about $30 unless you live in California. Degrease and scuff the panel with Scotchbrite and then BRUSH on the adhesive to both the panel and the vinyl. Let cure to the point that the glue doesn't come off on you finger when you touch. Press the 2 pieces together starting at the deepest part of the panel. Use a heat gun or a portable space heater to stretch some of the places that may need stretched. This vinyl works very well when it is warm and doesn't contract too bad if the weather gets below freezing. Should last for years... If you use spray can glue...the first warm day that comes along and the vinyl will start to lift... To get an idea, here is a center console I just wrapped in Katzkin. Single piece with no stitching. Heatgun, glue and vinyl...kickpanel at the top of the photo is the same thing and has a lot of stretching in order to cover the bottom section below the midbass driver. No wrinkles. That's why I like the Katzkin vinyl...very forgiving! I thought your second photo looked really good...nothing wrong with that panel! T
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 Last edited by par4tom; 04-28-2016 at 10:41 AM. |
04-28-2016, 10:08 PM | #8 | |
Btw that center console is awesome! How did you make that?? |
04-28-2016, 10:42 AM | #9 | |
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
04-28-2016, 10:06 PM | #10 |
Thanks everyone for sharing your thoughts! I can't wait to start doing some work to my truck! I'm gonna start with the door panels and paint the. Tan and white in the center if I am feel ambitions I might try to do the whole dash!
04-28-2016, 10:49 PM | #11 |
I would like to see some that cover the whole door..top to bottom
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
04-28-2016, 11:26 PM | #12 |
04-29-2016, 12:31 AM | #13 |
Here is a set we slapped together to make a show...they are being redone now. Picture is bad but just an idea...best picture I had...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 Last edited by par4tom; 04-29-2016 at 12:40 AM. |
04-30-2016, 05:25 PM | #14 | |
plywood backer, mdf frame, fiberglass structure, carpeted insert and wrapped in vinyl i wanted speakers in the door as well as the kicks and an arm rest where my arm actually went kicks to match
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-30-2016, 05:30 PM | #15 |
I saw your truck... Very good ideas and really really really well done...
05-01-2016, 12:02 PM | #16 |
thanks
i had a very detailed build thread over on fiberglassforums.com sadly that forum died... rip fiberglassforums.com
05-01-2016, 12:07 PM | #17 |
05-01-2016, 01:18 PM | #18 |
i learned everything about fg and door panels over on fiberglassforums.com
read my 58 truk build thread, i recreated most of the build here (link in sig)
05-01-2016, 01:25 PM | #19 |
Ogre's thread is a good one. A lot of outside the box thinking...
I had the upholstery shop do my door panels...thinking that after seeing Ogre's, I need to add a bit of fabrication to them...we'll see
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 Last edited by par4tom; 05-01-2016 at 01:32 PM. |
05-01-2016, 01:48 PM | #20 |
05-04-2016, 06:50 PM | #21 |
thanks, outside the box does take longer though
05-01-2016, 01:47 PM | #22 |
