Filler tube questions
The end of my filler tube is chewed up and I'm replacing it with one I'm picking up here on the board. http://67-72chevytrucks.com/vboard/s...d.php?t=276549
It shows some rust inside the neck that I want to clean out. I thought about pulling the rubber stuff off and having it sandblasted, but now I'm thinking about using a drill and wire wheel. Any ideas what to coat/paint the inside with to stop rust but not react to the gas? I don't really want to go to the expense of having it plated or powdercoated, but I also don't want it rusting again... Does anyone know how POR reacts to gas? Ideas? Thanks, Tony
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
Re: Filler tube questions
Eastwood has the gas tank material for coating the inside of a tank which should work well. I would also try your local radiator shop to see if they will coat the inside for a nominal price.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Parts and more parts
Try using the Glyptol, that Eastwood sells for coating the inside of engines.
Great ideas, guys. I should have thought of Eastwood... Now where did I see that radiator shop..?
