05-11-2016, 05:26 PM | #1 |
Eaton HO52 fill plug needed
I'm hoping someone out there replaced their rear end and still has their old Eaton HO52 10 bolt diff cover with the fill plug. I've tried every auto and plumbing supply store in Northern Virginia with no luck. The plug appears to be 1-inx20. I am really close to modifying my diff cover if I can't find a used plug. Please let me know if you have any suggestions-- the PO managed to get by with a load of Permetex around the broken plug. My '69 C20 Camper Special thanks you!
Shawn G. 1969 C20 |
05-11-2016, 07:30 PM | #2 |
Re: Eaton HO52 fill plug needed
Looks like 344829 is the number you seek.
https://www.google.com/search?q=344829+plug Might want to post a WTB over in the classified section as well.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-11-2016, 09:49 PM | #3 |
Tim,
That part number was the hint that I needed. I should have started on the boards before I drove all over Northern Virginia. Thanks again! Shawn
Shawn G. 1969 C20 |
05-11-2016, 10:05 PM | #4 |
I may have one, I'll check tomorrow. Just shut the shop down for the night. I think mine is a 12 bolt though, but I will check and let you know.
