What Do You Guys Do For Alarms?
I'm wondering what you guys do for alarms with your old trucks. I guess the best thing may be a kill switch. I don't want anything that will have to interact with the door latches/door handles. Let me know.
![]() Join Date: Sep 2016
Re: What Do You Guys Do For Alarms?
Personally, I was thinking of adding a kill switch under my air bags somewhere in the bed so when I park and lay it out, nobody can take it unless they can put air in the bags
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
Kill switch with removable key cam work ok. Wired so alarm functions atill work.
Kill dog, kill! I would tell you but then I would have to kill you. Yes,. I do have a 2 layer system in place. This is only good to stop an armature, a pro will just drag it onto a roll back and it's bye, bye. That's where a tracking system comes into play. Remember 2 layer.
Mr. Bond, James Bond
My '47 C.O.E build |
Alarms are so sophisticated today. I remember Eddie Murphy making a joke about talking alarms in cars ;;
"fool, someone stole yo battry!!!" |
So the thief
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" Last edited by capnduane; 11-08-2017 at 09:43 PM. |
#7 | |
#8 | |
That might keep the joy riding amateur from taking it but if a pro auto thief has it on his list it will get snagged with a repo rig cover and all. Then moved far enough that it can be tucked into an enclosed trailer and gone.
I'm not a fan of bagged rigs and think the laid out on the ground look is one of the silliest fads that car folks ever had stuck on them but laid out with an empty pressure tank and a hidden kill switch for the compressor would keep all but the the most creative amateurs from having success. They might get in, get around the ignition and get it started but if it won't raise up it isn't going to drive anywhere. I still like a locating system and that could be as simple as your scratched up slightly outdated smart phone that has GPS locating on it being run on the family plan for pocket change a month and hidden in the car with it's own auxillary battery hooked up to the charging system through a diode so it doesn't feed back to the electrical system if the rigs main battery is disconnected and narc it's self out.
ive always installed a kill switch which disables something electrical or fuel related so it still cranks over. my thinking is the thief will just think it doesnt run or is just a old pos and give up. my 86 i just disabled the coil on a kill switch so if they eventually find the kill switch the truck will probably be so flooded it wont start anyways.
remove door handles
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I leave the doors unlocked and the windows down so they can see this.
