06-18-2011, 10:14 PM | #1 |
Rubbing rallys on Rear.
I have my 68 suburban bagged with the CPP super track bar kit. Moser 5 bolt axels in the stock 6 bolt housing. it is a narrow 68 axel. I have 15 x 8 truck rallys with 275 60 15's . At ride height the axel is centered. The tires take turns rubbing the inside of the tub on turns some times the drivers rubs other the passengers. I am wondering if this is just a Suburban related problem. Is it safe to run wheel spacers on the back ?
Thanks, Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 06-18-2011 at 10:17 PM. |
06-18-2011, 10:23 PM | #2 |
Re: Rubbing rallys on Rear.
Mine would rub in the rear as well. I have now gone extreme drop and cut the rear out. But mine would rub there as well.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
06-19-2011, 12:18 AM | #3 | |
06-19-2011, 12:25 PM | #4 |
Anti-sway will help too. Front and rear.
