Keepin an eye out
Couple Steering Column Wiring Questions...
Hi All, going to a tilt and I had this middle piece between truck and column plugs (1st pic)
Now I have the 2 horseshoe plugs (2nd pic truck end on top) but they dont plug tight to each other and the colors are off on some of the wires..Do I need another middle piece? Lastly do these need to be connected to start the engine? Thanks in advance... ![]() ![]()
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Re: Couple Steering Column Wiring Questions...
I have factory tilt and mine plugs in with the curved connector. It will run just fine not connected, only controls turn signal, hazards, horn.
Take a few zip ties and tie them tightly together, that will hold them.
ditto on what was said about the signal lights/horn/flashers, without these connected, you lose a lot of important things..... Ben ![]() |
