01-23-2015, 09:03 PM | #1 |
Can't get rear leaf springs out
I'm trying to remove my rear leaf springs to do an axle flip. I can't get the rear shackles loose. I can get the nuts off without any problem, but the shacles won't budge. Anyone have any suggestions? Are they threaded? If so, how do you get them out? Thanks, jj
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
01-23-2015, 09:23 PM | #2 |
Re: Can't get rear leaf springs out
Truck is resisting being lowered?
I'd imagine the bolts are rusted to the bushing sleeves so you can't remove the bolts. Got pics? |
01-23-2015, 10:14 PM | #3 |
Yes, there is a threaded situation going on. The pin is threaded into the leaf spring. Where you are having difficulty is getting the shackle free from the pin. In the picture below you will see between the threads of the nut you have removed and the large threads that go into the leaf spring is a tapered section, your shackle is wedged onto this taper.
Knock the shackle free from the taper and you're good to go.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
01-23-2015, 10:45 PM | #4 |
Try putting some heat on it.
01-24-2015, 01:13 AM | #5 |
You also need to support the spring so that you have the least amount of tension and or pressure on it. I've fought that one more than once with the weight of the rear axle hanging on the spring. Even just the weight of the spring adds extra friction to overcome.
Some rust penetrate like PB blaster or heat would help a lot in breaking the shackles loose from the bolts.
01-24-2015, 09:09 AM | #6 |
Thanks!!! That's the info that I need! The pic really helped me see what I'm up against.
01-25-2015, 02:26 AM | #7 |
I had a hell of a time getting mine out due to them not being greased since it left the factory.
I found all the replacement parts bought separately was cheaper than getting new shackle kits: just so you know autozone carries the pins cheap $6pr http://www.autozone.com/parts/suspen...65_10195_1685/ and rare auto parts sells the threaded bushings $10 (if I remember right it was for a pair) http://shop.rareparts.com/smtp/shopd...040|SUSPENSION, SPRINGS & COMPONENTS and NAPA had the front bushings for the rear $10 think it was for the pair also http://www.napaonline.com/Catalog/Ca...450_0131133059 |
01-25-2015, 03:01 AM | #8 |
If you need to change the bushings when you get it apart it would probably be simpler to take the springs to someone with a hydraulic press to do/have it done as they are a real pain to do on the work bench.
01-25-2015, 03:23 AM | #9 |
mr48chev as you say :
"While I'm at it I may as well----" |
01-25-2015, 01:09 PM | #10 |
isn't there a tapered lock pin to remove on the front pin too?
your not going to reuse any of the shackle hardware, you can heat, cut or beat into submission the shackle the replacements are cheesy, at least the ones i bought from brothers were no nuts on the pins like stepside posted, just a 1/4'' bolt in between the plates i see that rusing out in a few years and the shackle blowing apart
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-25-2015, 01:53 PM | #11 |
01-25-2015, 03:50 PM | #12 | |
non of that will be reused and unfortunately that end is often the easy end the front pin ''slides'' out, first pull the tapered pin out that looks in the front pin i made a slide hammer to screw in where the grease zerk was try to center the spring on the pin as there is usually a wear spot that prevents the pin from extracting
01-25-2015, 02:17 PM | #13 |
The pins/bolt has a taper to it where the shackle is , should be able to take a pry bar and pop it lose ,take a few good wacks at it as it was pressed on by the nuts.
01-25-2015, 02:55 PM | #14 |
And yes lock pins secure the front pin in the eye of the leaf spring mount,they're tapered also.
http://www.rockauto.com/catalog/x,ca...parttype,13713 When I did mine I had the bed off . |
01-28-2015, 06:27 PM | #15 |
The front eye of the rear spring is SO much easier to do with the bed off.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
01-25-2015, 07:39 PM | #16 |
01-25-2015, 08:25 PM | #17 |
Mine came out easy, the po had just repaired using undersize bolts and garden hose to take up the slack. I discovered it in 85 when I put the new axles on. Sure road and tracked a lot better afterwards.
01-26-2015, 02:46 PM | #18 |
01-28-2015, 06:18 PM | #19 |
If you are replacing the spring bolts and bushings you can make use of a slide hammer. I had to also get the blind hole puller attachment with 1/2 -20 threads(same as spring bolt outer threads) and I welded two lug nuts together and hammered away. The bushings came out fairlly easy... and NOTHING came apart easy on the frame I had!
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
