07-28-2007, 10:53 AM | #1 |
Replacing GMC cabs
I need some expert opinions! My 1969 GMC has some rust issues in the firewall, kick panels & above the windshield. I bought a 1968 GMC cab that is much better condition in those areas & plan to get this one repaired & painted before swapping cabs. My questions are should I keep the '68 hand brake lever or modify the cab for the foot pedal parking brake? I like the look of the '68 hood more than my squared off '69 & need some advice on what has to changed to get a '68 GMC hood to fit a 1969 GMC front end. If it takes a lot of changing, we will probably cut & modify a 69-72 hood to give it more layback. My last question is about the chrome trim on the back of the cab, below the back window. How do I put the trim on a cab that didn't have it originally? I plan to get it painted red & white, since the '68 cab is original red. TIA!
1969 GMC C-1500 1972 Rally Nova 1988 Monte Carlo SS 2004 GMC 2500 Crew Cab |
07-28-2007, 11:17 AM | #2 |
Re: Replacing GMC cabs
the68 hood will not fit unless you change the whole front end
07-28-2007, 01:56 PM | #3 |
member #16
On the hood you only need to change the top bar on the grille to a 67-68 bar and im pretty sure the hood latch has to change. The GMC fenders are the same between 68 and 69.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 07-28-2007 at 01:57 PM. |
07-28-2007, 02:39 PM | #4 |
08-01-2007, 08:37 PM | #5 |
Ttt
07-28-2007, 02:15 PM | #6 |
Personally I like the 68 hand brake better than the 69 up foot brake, we have both styles and on manual trans trucks so they get used a lot.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
