Any luck routing dome light wire?
The original wire was on the truck but brittle and naturally broke when I tried to gently pull on it. Any ideas on how to route a new set of wires up there?!
Jeff
'59 Big Window Fleetside |
Re: Any luck routing dome light wire?
You might try using a piece of stiff single strand copper wire to shove though in one direction or the other and use it to pull the wire (s) for the light through. Pretty much as an electrician would use a fish tape to pull wires through conduit. Maybe even a piece of welding rod or a wire coat hanger straightened out.
Here is what I use............. a old broken inner speedometer cable, start at the top of the A piller and just let it slide down the inside of the post and pick it up just under the bottom corner of the dash
Yellow truck club
on of the guys on the forum used air compressor to blow a string line up then pulled a new wire.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
I couldn't get a new wire in so I ran it out through the firewall and down the firewall with the rest of the tailight and gas guage wires. Then I ran it with the gas guage wire up through the rubber grommet and then fished it up to the light.
Oh! Good call!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
![]() Join Date: Nov 2008
I used a piece of utility wire from the top down thru the front pillar to pull the wire up.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
i tried a piece of wire from the top and from the bottom for an hour with no luck.
i found some plastic banding (for strapping boxes together) and fished it from the top in 3 seconds.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
i lucked out and was able to use the old original wire - tied a new one on and ''gently '' pulled it all the way thru.- took a li''l time but i got it .
i also couldnt get threw the post in my 49, so i took a piece of rod down it an it felt soft so i kept jabbin at it an it finaly fell out an its was a bunch of junk that a rat had put in there i guess to live in, no tellin how many years that had been in there
![]() Join Date: Jun 2002
.035" tig rod fished thru windshield postworked for me
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
i worked on mine for three days and just said screw it and left it ,,lol i still cant get it threw the pillar under the dash and the old one i tied new one to broke in the middle
on my 57 I used heavy string and put a small fishing weight on end to drop from hole where visor mounts.then a length of mechanics tie wire to fish it up to headliner opening.did this on pass side for power antenna wires to behind pass door.
now u have everybody wonderin what is stuck in there, jab it dude jab it
