![]() Join Date: Oct 2014
Tail light question
My tail light wiring was pretty much chopped up when I got my truck. I kept the plug and about a foot of the wire coming out of it. I've restrung the lights myself. The regular lights work both sides. Turn signal and brake lights only work on the right side. I'm not sure what the issue is at the moment. I thought if the grounding was ok since it works both sides when lights are on. Maybe not. Does anyone have any thoughts?
![]() Join Date: May 2013
Re: Tail light question
check them with a test light at the rear crossmember , if its not working there you know the issue is towards the cab , if it is working , its in the rear wiring
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#3 | |
The Older Generation
If you don't have a ground wire from the frame to bed do that first. Then check the ground wire from the tail light wiring to the bed on both sides. I also had one that the whole socket turned when I pushed the bulb in and turned it, so the bulb never made complete contact inside. It took me forever to figure that one out..... LockDoc
Thanks fellas. I appreciate it. These darn lights are the only thing holding me back from get her back on the road.
