SM 465 Shift Leaver ?
Can someone please tell me how to remove the shifter assembly ? I have heard that it is the easiest way to refill the fluid after a change.
71 C-20 07 Magnum RT AWD |
All about them K’s
![]() Join Date: Jun 2014
Re: SM 465 Shift Leaver ?
Put it in neutral and push down and turn at the same time on the collar assembly assembly at the base of the shifter where it goes into the transmission. It will only turn one way and I believe it’s to the right to remove but it’s been a little bit since I pulled one of my shifters. Once you get the collar rotated pull the shifter straight up. There will probably be a little oil on the portion of the shifter that is in the top of the transmission.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
![]() Join Date: Dec 1999
![]() Join Date: Jul 2007
It's not usually that easy though you have to have some strong thumbs.
![]() Join Date: Feb 2002
General Motors used to have a Special Tool, that had a big T handle and a steel wrench with a cut out for the shift lever. Push down and twist, and the tin collar pops up. I made one, years ago, by cutting a 1/2'' wide cut out of one side of a 2 x 4 . Worked the same way, but it broke eventually. Still easier than using your thumb and forefinger. In my Twenties I didn't need no stinkin' Special Tool, but I can't say that now.
Thanks everyone ! I did this years ago when I didn’t feel like crawling underneath the truck. It’s not the fall that’s bad, it’s getting back up !
#7 | |
https://youtu.be/8yJuHd8CROs (approx 3 min mark) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-02-2024 at 12:56 PM. |
#8 | |
I'm shocked!
