Old member
Ok I want some input from all you bagged guy's. I installed the helper bags a few years ago and they work great.
![]() I have to put air to them through the schrader valves in the back bumper. I bought a Buick Park Ave Ultra air compressor for the suspension and mounted it. ![]() I have the Delco pleasure-lift gauge and air valve to release the air and I mounted a momentary switch to turn the compressor on/off. I didn't want a regular on/Off switch because I was affraid I would forget the switch and blow the bags up. ![]() My question is should I have anything else in the system to make it ride better for the system I have installed. Opinions suggestion's... ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Helper air bags
I would remove the spring and install just a standard 2600 bag,... for a better ride.
Some rear shock relocators and an adjustable track bar also.
#3 | |
Old member
![]() Quote:
Re: Helper air bags
Those must be old pics.
There is no shock relocator in those pics.
Old member
Yes they are. Sorry about that. Here is some of the new "No limit kit"locator's.
Re: Helper air bags
I was looking at this one,...
Old member
Yea those are several years old pictures before I had the relocator's on it.
It rides much better now. ![]() ![]()
