Old 05-14-2012, 07:18 PM   #1
dhughins
dhughins's Avatar
1969 brake lines?
I've just done a disc coversion and gonna have to replace most brake lines ad I can't get them off couplings/tees without rounding off the heads. Can't afford the brake line kits, so I'm gonna buy the straight pieces with the fittings already on them. Can anyone tell me what diameters I need and the closest length possible? I know the come in 40" 50" maybe 60".
dhughins is offline   Reply With Quote
Old 05-14-2012, 08:38 PM   #2
nogig
Re: 1969 brake lines?
Fronts are 3/16 backs are 1/4. I have no clue on lengths but a tubing cutter and flaring tool will serve you well. I had to finish a front brake conversion on the 69 i bought. It was pretty straightford. Also the hand bendable lines at Advance auto are a godsend. Good luck!
nogig is offline   Reply With Quote
Old 05-14-2012, 08:40 PM   #3
JimKshortstep4x4
You will need 3/16" diameter lines. My suggestion would be to buy a roll of tubing (25') and the number of fittings you need. You can then cut and flare the right lengths of line. I believe that you can borrow or rent the needed flairing tools and pipe cutter.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-14-2012, 10:23 PM   #4
BlackhillsHD
BlackhillsHD's Avatar
If youre going to get a tubing bender, get the kind with the handle that you draw accross the bend. They make much nicer bends then the old fashioned wrap around style. I just got done re-plumbing the front of my 4x4. I got two 60" pieces from napa for around $7 a stick.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
