Old 09-03-2020, 04:57 PM   #1
Jesster3757
are 1960 cabs the same up to 1963'
As far as the cab, the 60, 61, 62 and 63 should bolt on to a 1960 frame? right
thanks guys
Jesster3757 is offline   Reply With Quote
Old 09-03-2020, 07:14 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: are 1960 cabs the same up to 1963'
thanks guys
The 60-63 cab are wrap around windshields.
But the frame for the 63 is the same as 64-66.
The 60-62 cab will bolt right up to a 60-62 frame, but the 63 cab has a different location for the front cab mounts. 63 front cab mounts are in the same location as the 64-66.
But really, any of the 60-66 cabs will mount to any of the 60-66 frames, it just means drilling some holes.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-04-2020, 03:38 PM   #3
Jesster3757
Thank you "LostMy65", this info helps me out
Old 09-08-2020, 08:55 PM   #4
whateverpratt
Any '60-'62 cab will mount on any '60-62 frame without modification
Any '63-'66 cab will mount on any '63-'66 frame without modification
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
