Old 04-06-2007, 09:36 AM   #1
neverfinished
Instrument panel harnesses
Does anyone have a picture of where the harness for the temp gauge plugs into the Instrument panel? I think I have a break in the wire or the wire isn't connected. My temp gauge is bottomed out below the 100 mark. I tried grounding the wire at the sensor side but the needle didn't move. From below the dash I can't see where the harness/harnesses or even the speedo cable connect. They only gauges that work are the speedo and the fuel gauge, oil pressure and voltage are handled by gauges under the dash but no water temp gauge. I think that the instrument panel may have come out of a later model because it doesn't sit right in the dash and that may explain why the other gauges were replaced.
neverfinished is offline   Reply With Quote
