Resident Curmudgeon
![]() Join Date: Dec 1999
PROOF! Rust belt truck cabs originally had floors!
Check out this option sheet. Notice the E81 option! Anybody else got floorboards?
This may also put me in the running for least options, or at least the lamest options. After all every truck was painted, had a seat, vinyl trim and FLOORBOARDS!
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 09-09-2003 at 06:50 PM. |
Fabricate till you "puke"
LOL! i have floorboards......but my longhorn came from the "left coast".......didnt think they had floors in Illinois:p(its part of the AC package) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Formerly yellow72custom
Floor? What the he!! is that? I thought all of them had the footwell vent option
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Jeff,
I thought that "floorboard" meant that it had the high hump. Is this not correct? The trucks that we have with the high hump have "floorboard" on the glovebox door listing. Jim |
Resident Curmudgeon
Jim, this truck was a 250/ 3 speed column with a low hump. I have no idea what this option indicates.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Resident Curmudgeon
My 71 resto pack says E81 is a wood floor pickup box option. The descriptive wording "Floor Board" seems odd however. It's usually described as "Pickup Box Floor"
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 09-09-2003 at 08:45 PM. |
Non-flintstone version!!
I'm certain floorboard option indicates wood bedfloor in fleetside.
Bob |
What plant was that truck built at? Mine was built in fremont, ca, and it had the wood floor, but it doesnt say floor board on the option list (says something else, but I forget exactly what) I am wondering if each plant had some different names for the options/ From what I have seen, that would make sense.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Resident Curmudgeon
This one was built in Tarrytown, NY. It's a 71. It's the wood floor pickup box but e81 is usually described as "Pickup Box Floor" on every other truck I've seen. Floor Board just seems odd.
BTW, a one option truck if you discount the seat, paint and trim codes. I think they were included on this option sheet so it would not look so "empty".:p
Jeff,
That is the shortest option sheet that I have ever seen! Jim |
CCRider
On the option list that were posted on this board, E81 was listed as floor board equip.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
#12 | |
Resident Curmudgeon
All stock OE components BTW...boring...no fun to drive...noone ever looks at it...cookie-cutter POS.:p
GEARHEAD
Now you just need a new glove box door with the right options list.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#14 | |
Resident Curmudgeon
#15 |
THE QUICKER FIXERUPER
My panel only has 3 options listed Turbo Hydromatic (400) Auxillary seat and Dark green paint. And if you want a custom options sheet sombody on the board, I think it was Yukon Jack had one you could fill out and print.
