10-16-2013, 05:03 PM | #1 |
Where to get ethanol free gas
Just stumbled across this... Not sure where to post it because it should be of interest to everybody on this site. I'm so sick and tired of my power equipment getting trashed by ethanol laced gas and have been worried what it's doing to my truck. Finally found a (kinda) local source for clean gas. Here's a map of all ethanol free gas stations in the country. (Not sure how accurate it is so I would definitely call before making a trip).
http://pure-gas.org/extensions/map.html |
10-16-2013, 05:25 PM | #2 |
Re: Where to get ethanol free gas
places here in SC have alky free gas.Shell stations and a few mom n pops. Also Ive noticed marine gas is usually free. Pricey but...
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
10-16-2013, 05:38 PM | #3 |
it is very expensive here almost 1.50 more a gallon so i only use it for the mower weed wacker pressure washer etc
10-16-2013, 07:41 PM | #4 |
Farm Co-Op's. It's only 89 octane but a little booster and it magically 93-94 octane. And cheaper to boot. In Texas it is completely legal to buy and run on the street. You could also run AV-gas Can't run it in a EFI engine... but man will it liven things up! (not legal)
I run it in my boat and lawn equipment. (Farm gas) I smoked the motor in my boat last year due to ethanol burn. That stuff is bad news in a carbed engine.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
10-16-2013, 10:35 PM | #5 |
That is ridiculous! regular 87 octane is $.15 to $.30 more than the E10 equivalent in Oklahoma. I figure even if it does not harm the vehicle it is a wash when you consider losing a couple MPGs with E10.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
10-16-2013, 09:14 PM | #6 |
Had no idea. Thank you for the post.
10-16-2013, 10:32 PM | #7 |
I guess real gas is still plentiful in Oklahoma. Some gas stations have both E10 and regular. During certain seasons the 7-11s and others switch back and forth. I wont use E10 unless there is not another station around and I need gas, even then I will only get a few gallons. I go to Shell or Valero stations for quality non ethanol gas.
10-16-2013, 11:31 PM | #8 |
Can't buy real gas anywhere near me. None in the state of New Jersey at all. Unless its race gas or marine gas, nearly impossible to find in SE PA as well.
I got some real gas last summer in either TN or NC (not sure where I was at the time--- or what day it was) on a bike trip. Bike ran soooooo much better.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
10-17-2013, 08:55 AM | #9 | |
10-17-2013, 09:42 AM | #10 | |
The one on Vine St is way downtown (an hour in traffic), and the next closest one is almost an hour away but twice the distance. I'm not interested in risking my truck or my life in the city to get better gas. The others are approaching a 2-hour drive.
10-17-2013, 03:52 PM | #11 | |
10-17-2013, 12:53 AM | #12 |
is gas with ethanol really that bad for the older engines? I knew it was worse, but how much worse I am not sure
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
10-17-2013, 07:28 AM | #13 | |
It also attacks plastic and rubber, so fuel hoses and other soft parts will fail quicker with ethanol.
10-17-2013, 09:03 AM | #14 |
2WD Jimmy
Eastwoods has an alcahol gas treatment that may interest you guys.
10-17-2013, 04:52 PM | #15 |
Wow, there are about 5 times as many stations in CA as I expected to see. They are in one of the least populated areas, but there are some....I'm shocked.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
10-17-2013, 05:23 PM | #16 |
If you have a Quik Fill in your area check with them. One near me recently added an ethanol free 91 octane. Haven't pumped any so I don't cost.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
10-17-2013, 06:15 PM | #17 |
WOW! The map indicates one very close to me. I'm going over to check the next time I am out.
thanks for the map! |
10-17-2013, 06:49 PM | #18 |
would using StaBilt help over come problems associated with ethanol??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-17-2013, 08:59 PM | #19 | |
I use Seafoam for the gas in all my small engines, and it definitely makes a huge difference in how they run. Any stabilizing product should have a positive effect.
10-17-2013, 10:29 PM | #20 |
google peak oil.
Cool thing about ethanol (and SVO) is you can make your own... its basically moonshine well...not E10 but E85 is pretty close. I wish I was a chemist so I could elaborate more with some useful info. good link to know tho
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
10-17-2013, 10:46 PM | #21 |
Stabil will still cause issues if it sits for a extended period of time, I have seen carbs with stabil that has sat for a year, and there are harder to clean than a non-stabilized system. The one thing I have several customers trying is av-gas. So far no issues. I still expect to see exposed fuel lines and primer bulbs to rot though.
10-18-2013, 06:32 AM | #22 |
Here is a site that lists "pure gas" in NYS
http://pure-gas.org/?stateprov=NY
10-18-2013, 01:51 PM | #23 |
Location: Formerly MD and San Diego, now loving life in Arizona
It appears I will have to travel an hour to the NW or over 2 hours to the other Eastern Shore of MD.
Good to see that some good stuff is still sold in MD.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
Tags |
ethanol, ethanol free gas |
