Old 10-07-2015, 04:15 PM   #1
j.walters
j.walters's Avatar
Kents 62 knock out knee knocker
I'm posting this for my pops. What started out as a "flip truck" and a "rat build" took a quick turn. Having fallen in love with these ugly trucks It wasn't as easy to let go of. He acquired the truck in a trade and decided to build it for a fast flip. He decided to fix the rust and 200 hours later it has all new everything.
1964 swb bbw body drop on 22s ls swapped c10 build..
http://67-72chevytrucks.com/vboard/s...d.php?t=617623
j.walters is offline   Reply With Quote
Old 10-07-2015, 04:17 PM   #2
j.walters
j.walters's Avatar
Re: Kents 62 knock out knee knocker
The frame matched the cab pretty well. It was pretty nasty so it was sent out for blasting and then base and cleared
Old 10-07-2015, 04:19 PM   #3
j.walters
j.walters's Avatar
It cleaned up a lot better than we thought
Old 10-07-2015, 04:21 PM   #4
j.walters
j.walters's Avatar
what rot was in the frame was removed and repaired. which you will see later was then removed later haha.
Old 10-07-2015, 04:23 PM   #5
j.walters
j.walters's Avatar
He based and cleared the frame it looks killer at this point haha
Old 10-07-2015, 04:24 PM   #6
j.walters
j.walters's Avatar
new drop spindles for the disc brakes
Old 10-07-2015, 06:12 PM   #7
DakotaKid
id like to see more of the Gas tank install!
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 10-07-2015, 10:21 PM   #8
Turtleman
Turtleman's Avatar
WOW.. nice workmanship.. Nice booth... First time I've seen a dash replacement like that one
Turtleman is offline   Reply With Quote
Old 10-07-2015, 11:14 PM   #9
rwade
rwade's Avatar
Great build. Subscribed
Wade
rwade is offline   Reply With Quote
Old 10-08-2015, 01:11 AM   #10
azdude1964
azdude1964's Avatar
I'm digging the direction your going with this truck , got a bbw 63 in the yard
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 10-08-2015, 10:07 AM   #11
rwade
rwade's Avatar
What year is the frame? A 62 should've had the torsion bar front and "X frame"
And yours looks like a 63-66 frame
Wade
Old 10-08-2015, 12:56 PM   #12
j.walters
j.walters's Avatar
Ya we switched over to a 66 frame. the X is just too much of a pain in the ass.
I will grab a few more piks of the gas tank install here in a bit.
Old 10-08-2015, 01:10 PM   #13
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Great looking work. Looks like a fun project!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 10-08-2015, 01:12 PM   #14
j.walters
j.walters's Avatar
the rear of the frame was boxed in. He made a front mount with a piece of angle. then bent his lower mounts to set it to the depth that would hide it the most and keep it safe. Then bent some straps to hold it down from the top. used some anti vibe rubber strips all around it to keep it quiet and firmly in place.
Old 10-09-2015, 12:17 AM   #15
rwade
rwade's Avatar
I am not as familiar with these years and I was told the 60-62 cabs were specific to those frames as far as cab and bed mounts. If that is true what did you have to do to make it all work on the 66 frame? I've got a 61 is the reason for my curiousity.
Thank you, Wade
Old 10-09-2015, 09:55 AM   #16
j.walters
j.walters's Avatar
More piks or the dash annnnnnnnnd Who knows what the seat is ? and no it isn't from a 67-72.
Old 10-11-2016, 10:27 PM   #17
El Paso c10
Very nice work.
El Paso c10 is offline   Reply With Quote
Old 10-08-2015, 01:18 PM   #18
j.walters
j.walters's Avatar
well crap it wont let me add piks says I need to contact an admin...
Old 10-08-2015, 01:50 PM   #19
Classic v6 GMC's
Classic v6 GMC's's Avatar
Great work and I really like the dash!!!
Classic v6 GMC's is offline   Reply With Quote
Old 10-08-2015, 04:40 PM   #20
j.walters
j.walters's Avatar
here are those tank piks
Old 10-08-2015, 08:56 PM   #21
azdude1964
azdude1964's Avatar
Please give us more info on that tank is it a car or truck tank and where you got it?
Old 10-09-2015, 09:51 AM   #22
j.walters
j.walters's Avatar
Everything was the same except the front mounts. on this one he just drilled out a new hole and used new mounting hardware to fab up a new mount. the inner brace runs over the 66 frame in the same area. really easy.
Old 10-10-2015, 12:57 AM   #23
Captainfab
60-66 Nut
The rear bed crossmember and the crossills are also different since the '60-'62 frame is wider in the rear. However they can be modified to work with the '63+ frames.
Thank you, Wade
Old 10-13-2015, 03:47 PM   #24
j.walters
j.walters's Avatar
If anyone would know its him^. We haven't found that out yet since we aren't to mounting the bed. But now we know that its going to need to be modified. thanks Captainfab!
Old 10-13-2015, 05:19 PM   #25
Turtleman
Turtleman's Avatar
OK .. So stupid question?
"IF" you ever have to remove the tank,,, will you need to remove the bed first? From the Images it looks like the lower supports are welded to the frame?? Or am I just to old to see right?
