front shackles
hello !! i have a rookie question that i need an answer for . i just put a two inch lift on my suburban and while changing the front leafs i was shocked to discover that the outside bar on both sides was broken off the upper mount!! the bolt snapped at the frame. what i need to know is , is the mount a block of steel with two threaded "pegs" or is it a block of steel with a hole for a bolt? i live in wisconsin so rust is a problem and if this is a broken bolt then it being rusted in place is the only thing saving the other side from comming out! the diagrams i have of the part all show a bolt running through the "block" but mine is so rusted that it appears to be one piece . is it ????
this is also my daily driver so i cant start playing with it ( taking it apart ) untill i know for sure. ![]()
1989 half ton 4x4 burb 2 inch lift 33x9.50 tirers never ending project............. |
user # 2756
![]() Join Date: Jun 2001
Outside bar meaning the shackle itself? It is a 7/16" bolt running through a steel sleeve which inturn is held in a larger steel sleeve by the rubber bushing. You could replace the rubber bushing w/ a poly bushing. The ones ORD sell for about $15 includes the poly bushing, steel sleeve and new 1/2 grade 8 bolt. You need to go ahead and replace it.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
