Old 04-26-2004, 01:08 PM   #1
KShortell
KShortell's Avatar
No more oil leak! Choke light goofy, though. Sender replacement?
Woo hoo! I solved my significant oil leak.
I sat under the truck a couple of weeks ago with the engine running. I could see the oil dripping out of the mating surface between the oil filter adapter (for the factory oil cooler) and the block. I put on new GM oil cooler lines and a GM gasket/seal set for the adapter. No more leak! The only hang-up was that one of the OEM oil cooler lines is a bit short. We'll see how that holds up. I was disappointed, though, especially since they cost so much.
Of course, now my lazy oil pressure switch has gotten lazier. The choke light comes on more than it ever used to. It came on a lot yesterday, the first day I've done any towing in months. It gets worse when warm. My oil pressure gauge shows OK oil pressure, though. It's getting annoying and I'm looking at just replacing the switch.
Does anyone know which of the two senders on the top back of the block (next to the dizzy) is which? I suppose I could just follow the wires. Also, the FSM calls for a temp sender socket. Is there really a special tool needed or can I use something else?
I only ask up front before I tear half of the stuff off the top of the block that's in the way in order to get to it. Thanks!
Semper Paratus
KShortell is offline   Reply With Quote
Old 04-26-2004, 01:26 PM   #2
apstguy
LED King
apstguy's Avatar
The big can with one wire is the pressure sender, the smaller one with two wires is the pressure switch.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 04-26-2004, 01:48 PM   #3
Jonboy
Slots go on anything!
The oil gauge pressure sender is the one above the oil filter. That is the one you will want to replace.
a regular wrench is needed to replace the sender. I don't remember the size, but it should be 1/2 or 9/16. The flats are at the bottom of the sender.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-26-2004, 02:08 PM   #4
apstguy
LED King
apstguy's Avatar
OOps! What year is your truck? What I said only applys to 85's. All other years have the switch by the dizzy and the sender by the oil filter. In 85 the dender and switch are by the dizzy.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
