Old 04-27-2004, 08:38 AM   #1
71Rat
ran out of money
71Rat's Avatar
best posi??
I currently have an open rear in the back of my truck but would like to go to a posi or maybe a locker. From what i have gathered i would not be able to drive on the street easly with the locker. so right now i am leaning twords a posi but i have cooked 3 posi's in about 2-3 years and 2 were straight from gm and one was a jasper rebuilt. so i am looking for somthing that can handle going to the track every weekend and doing a nice burnout and still hold up for a while. the main reason i was leaning twords a locker was because it can handle the abuse of the track.
has anyone used an Eaton posi? what do you think of it?
Has anyone used an Auburn posi and what do you think of it?
thanks a lot
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 04-27-2004, 01:20 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
I bought my Eaton frpm www.tomsdifferentials.com for $280 and have been very happy with it. I don't think Auburns are rebuildable.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-27-2004, 01:46 PM   #3
Burt4x4
Burt4x4's Avatar
I granded an Pro-Auburn Posi, it was a nice and tight posi but it didn't last long..
Dana Power-Lok is what you want. It is as close to being locked without being locked. It is a rebuildable unit too. You can add or remove clutches to get a 'custom grip' if you like. They are not cheep.
www.differentials.com
I run them in front and back, great posi!!
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-27-2004, 02:53 PM   #4
71Rat
ran out of money
71Rat's Avatar
anyone else?
Anyone running high HP engines with a posi?
Rat
Old 04-27-2004, 03:06 PM   #5
cdowns
cdowns's Avatar
i have a moroso"brute strength" posi about$400 and has been in the truck for over 3years with no problems
Old 04-27-2004, 03:56 PM   #6
nightmare
nightmare's Avatar
eatons are rebuildable, where as auburns are not. if you can afford it, try going with an ARB Air Locker. great setup. a friend of mine had one in his mustang. 450 hp with about 475 ft/lbs of torque. withstood numerous burnouts. i recommend it
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 04-27-2004, 05:34 PM   #7
1969 GMC
1969 GMC's Avatar
The Power Lock is only available for Dana axles, and if he is talking about his '71, then he has a GM 12 bolt rearend.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-27-2004, 06:19 PM   #8
peppi
Rat those posis you cooked where they from 67-72 trucks? I was just wondering because i am in the same boat as you. I was told that the car posis are stronger than truck posis. Do you know if that is true? Manny
1968 C-10 Money PIT......
peppi is offline   Reply With Quote
Old 04-27-2004, 06:50 PM   #9
71Rat
ran out of money
71Rat's Avatar
the posi's i cooked were out of a 99 chevy tahoe 2 door with a 350.. 2 of them and one in an 89 k-5 lifted with 35's
rat
Old 04-27-2004, 06:55 PM   #10
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The Moroso Brute Strength is a very good posi, its a tight packed posi also, more for racing than the street. I had one in my 66 Malibu 12 bolt and it did ok on the street though. You can definately tell its a posi to and how tight its set up. It has extra springs and clutch discs added and the case is very strong.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 04-27-2004, 07:02 PM   #11
71Rat
ran out of money
71Rat's Avatar
were can i find out more information and place that sells a Moroso Brute Strength???
Rat
Old 04-27-2004, 07:38 PM   #12
cdowns
cdowns's Avatar
moroso; i got mine thru summit i think you'd have to call them i don't believe they have them in the catalogue
or just do a search for moroso's web site and they have a dealer find thing
Old 04-27-2004, 07:47 PM   #13
crazy longhorn
Fabricate till you "puke"
Try summit racing, or Jegs on the Moroso unit....they might be a little stiff for street use tho(twice the spring preload as a stock type eaton). I run a rebuilt factory eaton in my 12 bolt, & it does ok for street use. The new eatons run carbon fiber discs, & can be had about $100-125 cheaper than the Moroso unit. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-27-2004, 09:55 PM   #14
72C203503ONTHETREE
Jegs ans Summit both carry them, they only list the 12 bolt car but they also carry the truck 12 bolt and car 10 bolts.
Old 04-28-2004, 12:10 AM   #15
68c10owner
68c10owner's Avatar
there is a product called powertrax that replaces the spider gears in a open diff. with a spring loaded deal that loocks both axles like a posi. you don`t even have to set anything up just follow the directions.the summit part number for a 12 bolt is PWT-92-0788-3005. it just says 12 bolt, doesn`t say car or truck but it`s a place to start.
Anthony
68c10owner is offline   Reply With Quote
Old 04-28-2004, 02:49 PM   #16
71Rat
ran out of money
71Rat's Avatar
i was thinking about the powertrax untill i talked to a few guys about it and they said it loads up and releases around turns and makes a loud noise each time it does that. for the price it seemed real nice but now i am leaning twords a posi that is more streetable. Right now i am kinda inbetween a moroso and a eaton. both seem nice and about the same price.
Thanks everyone
Rat
Old 04-28-2004, 03:01 PM   #17
68c10owner
68c10owner's Avatar
if you go with a posi, i would get the moroso posi. 2 of my friends have them and they have been going for almost 10 years each and no problems and still very tight. i`m going to get one for my 70 when it`s time to build a rearend.
Anthony
Old 04-28-2004, 03:12 PM   #18
busterwivell
I've heard that the rear ends in 88-98 trucks are a real weak point. I know several people who have ruined them, and they seem a little hard to find in junkyards.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-28-2004, 03:49 PM   #19
cranknut67
cranknut67's Avatar
I am running a 12 bolt eaton posi with steel clutches and so far, with over 400hp in the truck it has not even budged.
I think it has alot to do with the steel clutches and the amount of pre-load you put on the unit on installation.
cranknut67 is offline   Reply With Quote
