Old 04-28-2004, 10:20 PM   #1
weasel29gm
SLOW BUT SURE,BUT CLOSER
59 Cab with a 55-57 front clip?
Need to know if a 55-57 clip will fit a 59 cab. A neighbor has a rust free 59 he got at the Auto Fair and wants to go with a 55-57 front. Any tips or comments. Thanks Weasel
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 04-29-2004, 12:22 AM   #2
Seon
Seon's Avatar
Yep, it'll fit but need to use the grill & hood from the 55-57 with them.
Seon is offline   Reply With Quote
Old 04-29-2004, 09:09 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I have seen it done, and it looked cool. A few years ago I saw a 58-59 fleetside with a 55-57 front clip. It took a minute to register what he had done, but I liked it
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-29-2004, 07:06 PM   #4
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
i believe the radiator mount is different too.........
the cabs from 55-59 are pretty much the same. the 55-57 fronts can be interswapped no prob, other than the unique 57 grille. the 58-59 fenders are different, of course, because they started the quad headlight configuration, but i believe the 58-59 hood will still swap, though it drops in the center unlike the 55-57. also, the 57 hood has dual raised strips on it.
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 04-29-2004, 10:04 PM   #5
weasel29gm
Cool thanks for the info, will pass it on.
Old 04-30-2004, 02:16 PM   #6
dubie
dubie's Avatar
are the hoods hinged in different places to??
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-02-2004, 11:49 AM   #7
ShamrockCustoms
Project56 on hold
I'm pretty sure the hinges are mounted in same spot, been awhile since I have been under/in a 58-9 tho......
Shamrock Customs
Old 06-16-2004, 01:19 AM   #8
Apache
Apache's Avatar
The 55 - 57 front clips will bolt straight up to the 58 - 59. The hood hinges are in the same spot, but I believe one of the holes are off, so you may need to drill a hole. I have a 56 Viking front clip on my 58. Its about 4 inches wider then a stock 1/2 ton, 3/4 ton, 1 ton truck front clip. And has its own unique grill. Not sure about the regular 55 - 57 front clip radiator mounts, but I know the bigger trucks are different. Because I had to change mine. Basically every single part off a 55 - 59 will fit from one to the other.
Apache is offline   Reply With Quote
