Old 05-02-2004, 11:25 AM   #1
My Boy's Toy
Axle ?
Jest brought home the next project . 72 K-20 , trying to figer what axles I have ? It has a NP205 & Option code 1G8610 - no Slip rear axle . how common is this. & were would my axle code be? Thanks Paul
My Boy's Toy is offline   Reply With Quote
Old 05-02-2004, 12:02 PM   #2
Truckstuff
Truckstuff's Avatar
Axles
Hey. If stock the front axle will be a Dana 44. The rear axle, It will be a Dana 60 or the HO72 Eaton. Do you mean (No Spin Rear Axle) if so its the Eaton. Big round insection cover with a removable 3rd member.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 05-02-2004, 12:11 PM   #3
Truckstuff
Truckstuff's Avatar
Heres a Pic of the Eaton.
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 05-02-2004, 12:32 PM   #4
My Boy's Toy
Thanks truckstuff , Your right No spin . Great Pict & that is it . is this a good axle ? & How did you do your Rear Dic Brakes , Nice Pick , Paul
Old 05-02-2004, 12:45 PM   #5
stomper72
I have a 72 3/4 ton and it has a Dana 44 in front and did have a Dana 60 in back till I put a 14 bolt in.
stomper72 is offline   Reply With Quote
Old 05-02-2004, 01:48 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yeah it's either a H052 or H072 only difference is the size of the rear drums. It's the predeccesor(sp?) to the 14 bolt. Has a 10.5" ring gear typically 4.10 or 4.56 gears. Only traction device is the no-spin AKA detroit locker, no longer made but was available in vehicles from 1948 to 1972 or something like that.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-02-2004, 01:58 PM   #7
Truckstuff
Truckstuff's Avatar
Axles
I have never had a problem with the Eaton, it is an excellent axle, basically a early 14 Bolt axle. The No Spin Rear Axle means its a Detroit Locker. The disc brake conversion is the same as the 14 Bolt, but with different spacers between the flange and the backing plate. I made my own brackets. Mine is also a No Spin. Parts are getting harder to get, thats why alot of people switch to the 14 Bolt. If you got it, run it.
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 05-04-2004, 12:21 PM   #8
justinf
The eaton is a good axle, like was said, it's basically a 14 bolt. If you have problems, 14 bolt shafts, carrier, etc. will fit in the housing. The benefit of this axle over a 14 bolt is diff clearance.
1981 CJ7 - 350TBI, sm465, np205, D60, 14bolt, 5.13s, detroits, 38.5 SX's
1998 Z71 extended cab
1998 Tahoe
2001 Tahoe LS - FOR SALE - $18,500
justinf is offline   Reply With Quote
Old 05-04-2004, 12:26 PM   #9
1969 GMC
1969 GMC's Avatar
i recently purchased an Eaton with the No-Spin (detroit), if you ever take the diff cover off to check and see if the No-Spin is still inside, take a look at the photos in the link in my sig. they should help you out some.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-05-2004, 05:15 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
justinf, Do you have some pics of a eaton w/ the 14 bolt carrier and shafts? This has been talked about before but nobody has actually seen it. Does the carrier use the eaton bearings or will the 14 bolts bearing need to be installed also? Could be a good upgrade more splines on shafts and cheap detroit lockers!
Old 05-05-2004, 09:12 AM   #11
justinf
I don't have any pics right now, but my brother has one from a dually with the 14 bolt carrier, shafts and detroit in it. I can find out from him if it uses the 14 bolt bearings. I believe it does.
1998 Tahoe
Old 05-05-2004, 09:41 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
justinf, any info you can provide would be appreciated. I have an eaton w/ 4.56 gears and open diff, would like to lock it! I wounder if a "lunch box" 14b locker and 14 bolt axle shafts would fit in the eaton carrier, hmmmmm
Old 05-05-2004, 10:37 AM   #13
Destructo
They don't offer lunchbox lockers for 14 bolts yet, I think just about the only thing you can get is a full detroit.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 05-05-2004, 11:04 AM   #14
justinf
Yeah but a full detroit for a 14bff is simple. It reuses the original carrier and is cheap.
1998 Tahoe
Old 05-05-2004, 11:08 AM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Powertrax makes the Lock Right and No-Slip for the 14 bolt.
Old 05-05-2004, 01:41 PM   #16
1969 GMC
1969 GMC's Avatar
the lock right and no-slip are each $400, the detroit is $350 for 14bff applications.
i am curious about using the eaton housing with 14bff innards, i think it would be the best way to go.
1969 GMC K2500
1996 Honda Accord
Old 05-06-2004, 12:52 AM   #17
Budweis
Geared for Collision
Budweis's Avatar
looks like i have an eaton as well. that sucks to hear brake parts hard to find as getting ready to go through mine this week and just went through this prob on the front. anybody know a link for any manuals or anything on this thing. really no problem with mine besides brakes but taking it out and figured id freshen it up while out. any recommendations on what all i should do to it to freshen it up while its out? hope i can get all the parts i need.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 05-06-2004, 02:22 AM   #18
1969 GMC
1969 GMC's Avatar
there is a disc brake conversion available for the Eaton, or you could make your own brackets and use a mishmash of brake parts to get it to work. Anyway, the kit is around $400, IIRC, with new rotors and calipers.
1969 GMC K2500
1996 Honda Accord
Old 05-06-2004, 11:51 AM   #19
drink2mny
drink2mny's Avatar
Here is an option 1969 GMC was talking about..
GM rear disc brake kits
Just scroll down you will see our Eaton kit..
I would also be interested in seeing how the 14 bolt axles and carriers work in the Eaton...
Support The Board
drink2mny is offline   Reply With Quote
Old 05-07-2004, 08:06 PM   #20
gmc71
gmc71's Avatar
Hey.... What would have come stock on 67 K20? I would like to change to disc up front are the stock front axles worth anything?
gmc71 is offline   Reply With Quote
Old 05-07-2004, 09:10 PM   #21
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
You can use any axel from a 71 or 72 and get disc.
You'll just have to match gear ratios with the rear.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
