Careful, they attack...
Just bought a new welder!!!
I got a Lincoln Pro-MIG 175 off ebay for $400. I haven't seen them anywhere for less that $550. I am so geeked. I've been kind of at a stand still with no welder, so this should get things moving again.
Howzit?!?
Sounds like a good score!
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
WELDER
Sounds KEWL I need to swap mine over to mig kit right now it's gasless which does decent but would be waay better. now I'm working on my 48 chevy fleetline need to do a little welding on it.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Almost done!
I've been wanting a new welder, but I think my wife would kill me. Sounds like you got a good deal.
I haven't told my wife about it yet. She will kill me. It's coming to my office so she won't see it when it arrives. Maybe I'll just keep it there for a while and use it, then just bring it home like it's nothing new. I am going to need to get a gas tank for it too. I should be able to rent one, you think. Or should I buy one to have as my own? It should be here this week. I am so geeked. I have a couple fenders to practice on too. Now I can finally start making progress on this thing.
#6 | |
Stepsides Are Bedder
A couple of other things...if you keep your (owned outright) bottle past the date of the last hydro-test, you may have to pay the cost of the test if the welding supply notices (typically, they don't). It's not expensive ($12.50, the last I heard, but that was a while back). AND, most importantly, before you buy the bottle...ask how much a refill is for the various sizes of bottles. You may find, as I did, that it is quite a bit more expensive to fill a small bottle than it is for a larger one, in terms of $$ per cu. ft. of gas. Let that help determine which bottle to buy. Lastly, should you decide to buy outright, BE SURE TO HANG ON TO THE RECEIPT FOR THE BOTTLE. That is your only proof that you are the legitimate owner. Bottles are stolen or misappropriated nearly every day of the week, so be sure to protect your investment. |
Insert funny comment.
![]() Join Date: Dec 1999
What do the smaller bottles typically cost? Im about ready to buy one myself and have no clue what to expect.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
The flux core is good to practice with, but it sputters (arc fluctuates) more than the MIG process. Also, the flux floats on top of the weld puddle, so it's kind of hard for a newbie to get a handle on what's going on underneath...but by all means, have at it! There is no substitute for "hood time" (time spent welding).
Remember to push (forehand) with MIG and drag (backhand) with flux core, although there are situations where you might want to reverse the above. Also, use flux core on thicker sections because it has better penetration. MIG is better at the thin stuff...use .023" wire for sheetmetal to practice with (it's more forgiving). Maybe you have an old fender or something to play with...turn the welder 'way down low and go from there. One last thing...get a feel for grinding your weld beads. You'll find that the weld bead is a lot harder than the metal being welded, so practice your technique and adjust your welder until you get a good, flat weld where not a lot of grinding is needed. Alternatively, there is a wire called EZ Grind, but I've never used it. Most importantly, have fun and enjoy your purchase!!! Please post what you find out about the bottles! Last edited by Stepsides 4Ever; 05-05-2004 at 12:33 PM. |
Got my welder, went to the gas place and this is what I found out. I got a 40CF bottle for $85, that is bought outright. The bottle came full. Refills are $20, and if I want to go bigger, I can turn in my bottle and just pay the difference in price from my bottle to the bigger one. Guy said the 40CF bottle would give about 3.5hrs of trigger time. I will see how long it lasts and go from there. The guy was very helpful and didn't try to pressure me into buying a bigger bottle or anything. The difference in refilling the larger bottles was only about $4-6 as you went up. I got my bottle from AGA in Madison Hieghts Michigan. Time to go welding.
Now you're talking! Most excellent!
Now you need to get one of those auto-darkening helmets... |
That will be next. I'm using my neighbors helmet right now. It came with a hand held shield, but it's hard to hold with one and and weld with the other. I've seen the auto helmets for as little as $50 in like Harbor Frieght. They have retail store nearby, I might have to make a trip and get one.
You can hide the welder in the shop, she won't notice for some time.
I hid a birthday present there and still hasn't been seen..
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
![]() Join Date: Feb 2000
I too have been bit by the welder bug. I got a Hobard 135 back at Christmas. Waited until March to buy a tank, Got a tank and realized I needed a cart. Man they wanted $100 for a cart so I made one out of a scrap equipment stand and 2 drawer from a workbench. Then mounted the 135 on top., and the tank behind. Sorry no pics. My tank cost me $205 full, bought out right.
#14 | |
I bought a Huntsman auto-darkening helmet some years back and I really like it...paid nearly $300 for it. The only negative is that, if you get in a position where the light sensor can't detect the arc your helmet will flash clear. We recently bought one of the Harbor Freight auto-darkening helmets at work and it seems OK...a good value for the money...the only thing I notice is that it doesn't seem to be as fast at auto-darkening as the Huntsman, but maybe that's just my imagination. I've worked with guys that weld for a living and some will not use an auto-darkening helmet because they feel that the UV effects are cumulative, and even that 1/250,000 of a second of exposure, over time, will cause your eyes to go bad, but most lenses that I've seen block the UV whether they are on or off. I dunno... But that is the hardest part about welding, especially as you get older...you have a hard time seeing the crack (slight pun intended). That's all the more reason for vee-ing out your work... |
