Old 05-04-2004, 12:51 PM   #1
cranknut67
cranknut67's Avatar
Transmission question
I have gone through 2 " bulletproof" th350's in the past year ( built with redline clutches and hardened sprags etc" and am finally going through the 3'rd one this week - I brought it in to the trans shop for a new build and can't figure out what to do... Should I have him build me a 4l60E and be done with it ( 1700.00 ) or should I wait for a 400 case ( 1200.00 ) to come available? I have a 900$ credit for the th350 coming because it has come apart 3 times - 500+- hp at the crank kills it?
wich is stronger?
cranknut67 is offline   Reply With Quote
Old 05-04-2004, 05:16 PM   #2
dmnall
dmnall's Avatar
I would recommend if you are going to go with a 4L60E then why not go with a 4L80E tranny as that will be able to handle the hp your engine is pushing. Otherwise I would recommend a T56 6 speed Manual!!
Charlie
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Old 05-04-2004, 06:19 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
500 horses in front of a TH350? I'm no expert, but that does sound a bit excessive.
Cat Fuzz is offline   Reply With Quote
Old 05-04-2004, 06:28 PM   #4
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The 4L60E is just a Turbo 350 with an overdrive basically. Actually its the newer version of the 700R4 but with electronics. You will need a stand alone computer to run the trans also. You will need other things like shortened driveshaft, throttle cable to the carb, etc.. Wait for a Turbo 400.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-04-2004, 06:35 PM   #5
jmanz69
Careful, they attack...
jmanz69's Avatar
I would agree with the 4L80-E. If you have that much HP and beat on it like it sounds you do. The 4L80 will handle it. It's like a TH-400 with O/D. You will need to have some other work done. Mostly computer,and D/S. You shouldn't be able to kill it though. It would be worth the money for you I think.
jmanz69 is offline   Reply With Quote
Old 05-04-2004, 06:48 PM   #6
cranknut67
cranknut67's Avatar
thanks, I actually went to the trans guy today and we settled on the 4l80e with a stand alone for the lock up 4th. - with kevlar clutches hardened sprag and vette servos and some othe cool goodies brought it back up to 1900.00 - it should be a sweet setup! - especially since I am going to tear it out and stick it in the 70 SS nova I found - I hope to pull wheelies!!
Old 05-04-2004, 07:33 PM   #7
my69camaro1
Young One
I run a turbo 350 that I rebuilt with a b&m kit in my 69 Camaro. Stock body/interior.
On motor 11.30's... juice 10.60's... Has a 5,500 stall. Got the biggest trans cooler I could find and an extra deep pan. Shift at 7,000rpm at the strip. 535hp+/-
Anyway, overdrive would be a big plus. Save your money and get a computer operated trans.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 05-05-2004, 05:45 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Does that price include the stand alone computer?
Old 05-05-2004, 02:38 PM   #9
cranknut67
cranknut67's Avatar
Yeah, it covers removal of the old trans, and installation of the new trans and he is going to wire it up with the lock up kit from TCI.
Old 05-05-2004, 06:49 PM   #10
jmanz69
jmanz69's Avatar
Just a thought, if it only needs a lock-up kit, then it might not be a 4L80E. Could be just a 4L80. the 4L80E NEEDS a computer to work, not just something to tell it when to lock in 4th gear. Make sure he isn't selling you a 700-R4 for way more than it's worth.
Old 05-06-2004, 06:44 AM   #11
Bowtie67
Bowtie67's Avatar
I thought all the 4l80 and 60's were elctronic and needed a computer for them. TCI sells a built and modified 700R4 to handle 700HP and I beleive the price was around $1400. I do hear the 4l80's can handle more power, when I was looking for an OD unit I looked at both the 700R4 and the 4L80 the 4l80 at that time was a couple hundred more and the computer is what killed the deal because at that time it was almost as expensive as the trans was. I don't run my truck at the dragstrip but I do beat on it a bit and my engine is no slouch either and the trans with a lockup in 4th gear has held up well.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
