![]() Join Date: Feb 2000
Well a little of this, a little of that and now that bad boy fits!
As some of you know, I am swapping in a 454 in place of the 307 and ran into major firewall problems. In the end I increased the body lift a bit and as you can see made a few minor firewall mods. ![]() My plan is to at some point go in and move the engine forward so I can go back down to the 2" body lift. This combined fix gets it where the body guy can get done, I can enjoy the truck and then when I'm ready for another project I can go in and move the engine forward. To avoid having to move the engine forward the firewall mods would have ended up being pretty severe. I really can't see how some people are able to do a 3" body lift and light massaging on the firewall, though I know they have as I have seen pics. ![]() ![]() ![]() ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 11:22 AM. |
Now you can set that timing when you're driving
![]() Joe |
Resident Curmudgeon
![]() Join Date: Dec 1999
Holy crap. That is some severe surgery there. I hope Doctor Boz-all was licenced in the state of KS. If not maybe you should sue for malpractice.
![]() I did not envy the position you were in, I suppose a 292 was out of the question? ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
that looks pretty clean, how are you planning on patching the holes? it is kinda weird, because i got a 454 in mine with no body lift and i only had to bash the firewall in a few places for it to fit. keep the pics coming thanks
Ryan |
I haven't worked with BBCs much, are the newer motors that much bigger than the original 402s that went in these trucks...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
![]() Join Date: Dec 2003
OUCH..... Those really are some severe mods.... oh well at least the truck won't be out of commission any longer that need be.
https://www.ebay.com/itm/29620574751...mis&media=COPY |
bigvinnie, the 67-72 4wd's did not have a big block as an option.
CPNE, no sawzall here, just a good ole cut off wheel but I guess that probably does fall under Doc Boz-all territory. (At least my dash remains uncut!) With carpet this mod should not be too noticeable - unfortunately I just didn't have much in the way of options that could be done at the moment. Ryanroo - the pieces that were cut out will be built up and outward a bit to cover the holes.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#8 | |
I didn't know that, does a 2WD truck have a different firewall to accomodate the big block?
72 Cheyenne Super 4x4 SWB |
Fabricate till you "puke"
the firewall is the same on the cabs, just the eng positioning is different for the BB 2wd trucks. 4 wd sb sits in I 6 position(for 2 wd), the factory sb (2 wd sits about 3 1/2" farther ahead than the I 6, 2 wd , or sb 4wd. the BB comes somewhere tween those two spots on the 2 wd truck. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Currently Blazerless
I'll bet it was hard to bring yourself to start cutting on that beutifull cab!!
How much body lift does it have now? |
GO VOLS!
I will have to do the same thing to my '72 K5. Already test fit the 402BB and "rough" cut the needed clearance. Fits like a glove.
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
67 is sold
Wow - almost like a G-Van now
Plexiglass - hmmm.
Okay, j/k.
WOW!! I think I would have gone for the moving the engine forward first before having to touch the cab like that. Where you gonna put the gas pedal?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
#15 |
I am probably going to graft in a throttle cable setup rather than the throttle rod setup that this truck had.
#16 |
You may want to look at Lokar's Eliminator Floor Mount Gas Pedal
FMG-6097 This bolts to the floorboard and has a cable assmbly that mounts under floorboard. I dont think you will be able to draft any stock setup, http://www.lokar.com/thottle_assemblies.html ![]()
#17 |
That reminds me of a couple holes I cut in the longhorn to fit a 455 Olds.....once you go "custom" you will never go back to stock
#18 | |
A splendid one to behold
67 swb 02 wrx |
#19 |
Almost done!
You are a very brave man! If your brakes go out, you will have a Fred Flintstone hole to use to stop.
I hope everything works out.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
#20 |
Happy to be here
![]() Join Date: Mar 2000
It's only sheetmetal. This shows you "ain't skeert" to cut one up....
#21 |
Blazerman - unfortunately the body lift had to be 4" - I will be moving the engine forward so I can get the body lift back down to 2" - but that will have to wait until I have more time for another project and $$.
#22 |
My other Love
hey its a good hole to spit out of or to chuck your sunflower seeds out of
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#23 |
The Blazer King
I think your rig needs some 38's now. To go with that lift. Good job.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#24 |
I was thinking the same thing about tires. I will have a total of 11" of lift now
#25 |
Body guy got the sheetmetal work done on the firewall. The inside is going to be hidden mostly by carpet so keep that in mind as you look at the pics. I'm pretty pleased with how this turned out. I think the gas pedal is going to work well still, I was a little worried before.
![]() ![]() Here is the inside passenger side ![]() And outside passenger side ![]()
