05-06-2004, 05:17 PM | #1 |
power brake conversion
i have a couple of questions about a power brake conversion. my 71 has front discs and manual brakes.
1) do i need a new porpotioning valve and master cylinder, or can i use the ones from my manual set up? 2) i just changed all of my brake lines, calipers and wheel cylinders during a brake change. will i need new ones for the power set up? thanks for ya'lls help. |
05-06-2004, 06:50 PM | #2 |
You can use the same master and p-valve. The rest of your brake stuff will be ok also. You should be able to get by bending (carefully) your lines to the master to move it forward a little to make room for the power booster.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-06-2004, 07:07 PM | #3 |
its all about the +6 inches
Basicly, unbolt the master cylinder fron the firewall, and slip the booster inbetween.
05-06-2004, 11:22 PM | #4 |
Its pretty much a piece of cake. (Knock on wood.)
I just finished my power brake conversion less than an hour ago. Just make sure you get the power brake pushrod (from the pedal to teh booster). The hardest part was just bleeding the brakes, which is only b/c I'm slying solo. Good Luck John
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
05-07-2004, 12:59 AM | #5 | |
Watch out for your cornhole !
